Gooserider
Mod Emeritus
Not a Garn expert, never seen the inside of one, but I don't understand why the Garn would work any different from other storage setups, where mixing is generally considered undesirable... I would also think it best to get the hottest supply water from the top, and return the cooler water to the bottom, hopefully in a way that would discourage mixing...
It would seem that unless there is hardware inside the tank that would be in the way, that it should be possible to add an extension to the top intake pipe with minimal draining. Just pull down low enough to get that connection above the water line, and pull the fitting. Make a setup with an extension that you can screw in, then mount it in the hole. I would probably go in the top manhole and try to rig up some support for the pipe as it goes by.
I'd probably try to make the extension long enough to almost reach the front of the tank, cap it, and drill a series of holes in it, possibly making the holes larger near the far end, such that the area of the holes was far greater than the area of the pipe. Position the extension so that the holes are on the top side. Alternatively, not put a cap on the end, and then you'd be pulling from the same general area as the front thermometer dial...
Either way you would be preventing any potential short circuiting, and hopefully pulling from the hottest portion of the tank, without inducing any added turbulence.
Gooserider
Gooserider
