av8roc
Very informative review, thank you!
I'm having mine installed on Thursday and I appreciate the tips.
chuckda4th said:Thought I'd put in another update for anyone getting it installed soon or recently.
I typically start the unit around 5pm, get it fully going and put in my last load around midnight and go to bed. Usually keep the draft at about 3/4 open, as that's the best "smoke on the glass when I wake up" to "longer burn time" ratio I've found. Only seeing the furnace kick in around 730am for about 20min every morning, which brings upstairs warm enough to get ready for work. Colder days (has happened 2 or 3 times in the 2 weeks), I'll get it going again in the morning and keep a small fire going all day (1-2 logs at a time), which I find keeps the house warm enough when I'm working upstairs in my office with a few computers around me that I'm comfortable (also has the added benefit of not having to re-light from scratch). At 5 i then just load it up again.
Main thing I've been surprised at is the amount of wood I've gone through using the above methodology. In the 2 weeks I've been running as such, I've gone through between 1/4 and 1/3 of a cord of wood. Knowing it's only going to get colder and i'll run it all day long a bit more often later in the winter, I'm estimating I'm going to go through about 1 cord of wood every 5-6 weeks. This means if I want to run all winter through early to mid March, I'm going to have gone through about 3! cords of wood.
Where I live I don't have enough yard to hold 2 cords, let alone 3 (besides the fact every square inch of grass I have would then be covered in wood piles), so luckily the guy I get my wood from said he would charge me the 1 cord rate (like $50 less than 2 1/2's) and just deliver 1/2 cord today, and another 1/2 cord in about 3 weeks to keep me going. He guaranteed me he'd still have the same quality wood for me.
So...just fair warning to potential stove buyers...make sure you have plenty of room for wood (at LEAST a cord and even then only if you plan on doing full burns 2-3 nights a week all winter), or can setup a delivery plan of some sort, otherwise you won't be burning for long.
All in all...still love the unit. A bit of work to clean up here and there and move wood around, but when the thing is kicking it puts off MAJOR heat and best off, doesn't look like some afterthought that was just tossed in your fireplace like I always thought the majority of the Hamptons and Jotols looked like IMHO.
I am a newbie with the Montpelier also. Ours was installed about a month ago. I was wondering how often do you clean out the ashes using your burning routine? We do not burn all day, sometimes in the evenings during the week and then on weekends. How hot do you run it, do you have a thermometer on it? We are trying to learn how to correctly operate it efficently. Thanks for your help.
chuckda4th said:I am a newbie with the Montpelier also. Ours was installed about a month ago. I was wondering how often do you clean out the ashes using your burning routine? We do not burn all day, sometimes in the evenings during the week and then on weekends. How hot do you run it, do you have a thermometer on it? We are trying to learn how to correctly operate it efficently. Thanks for your help.
I've cleaned them out 2x so far including today, so thus far I'd say weekly. It seems like when the unit is kicking and the secondary combustion is doing its job it is really efficient at burning everything to as small, fine an ash as possible, which makes it so I don't seem to have to clean it as often. Even still, remember that you want to keep a 2" layer of ash in there even after it's been cleaned.
I do not have a thermometer on it, however I have definitely noticed a correlation between where I have the damper when I go to bed, and how cloudy the window is in the morning. It seems like most of my fogging happens when the fire is on the later hours of the burn as even if I load it up at 11pm and stay in the room until 1am like on the weekends, it's still clean when I go to bed and a bit dirty in the morning. That being said, 90% of all the fogging disappears within 30min of getting the next night's fire fully going, so it's really a non-issue as far as I'm concerned. I probably don't run it at full "heat efficiency", but I would say I have a nice system going which gives me more "work efficiency", which reduces the amount of time I have to spend cleaning/maintaining it and still plenty of heat to be happy with. The amount of time I spend cleaning/maintaining it is more important to me than a degree of warmth in the room at 7am. I'm sure I could eek out another hour of burn time if i really wanted to, but then I'd bet I'd likely have to clean the glass much more often.
I also would by no means claim to be an expert at this. I'm still learning myself, and from what I've seen on these forums, YMMV to some degree with all of these tips. Some people have to run with their damper 3/4 open all night long (most likely external fireplaces like mine), while others can get away with it only 1/4 open and have full raging fires with no fogging (most likely internal).
nwohguy said:chuckda4th said:I am a newbie with the Montpelier also. Ours was installed about a month ago. I was wondering how often do you clean out the ashes using your burning routine? We do not burn all day, sometimes in the evenings during the week and then on weekends. How hot do you run it, do you have a thermometer on it? We are trying to learn how to correctly operate it efficently. Thanks for your help.
Wow, i am amazed I have been cleaning all the ash out after each burn. Are you saying you leave a 2" bed of ash inside the firebox after you clean out the rest? Do you still have a fire going in the morning after a all-night burn or just some hot coals? And does your glass get dirty during the day when you are burning a log or two at a time?
av8roc said:I can also close the air control completely with a full load of wood overnight and I'm lucky to find hot embers after 5.5 to 6 hours.
av8roc said:Anyone do the dollar bill test on their doors?
I've been burning for a week now and have certain spots on the door that always accumulate fairly thick fogging. They are especially concentrated on the hinge side of the glass door. I did the dollar bill test and confirmed by lighting a match while burning next to the seal that there are air leaks where the glass is fogging. I tried tightening the door latch and even adjusted the hinges but I still cannot get a tight seal on the right side and thus the glass never burns off that buildup when I have a good fire going.
Going to call the dealer tomorrow about the issue but I wanted to see if you guys have had similar experiences.
Thanks
Wildman_fab said:Couple of questions for you guys,
Where are you putting your thermometers on you stoves? What are you seeing for temps?
What temp is your fan kicking on at?
With good dry wood (1-3 years seasoned) I am getting an excellent fire going, with the temp on the door reading 300-400 the fan will kick on and run for a while, then kick off. Is there a problem with the temp pickups or a fan issue with these? It moves a ton of air, and only makes a little bit of noise *I had a rattle when first installed, but fixed it* It really puts the heat out there but only with the fan on, and its getting cold and WINDY!
Wildman_fab said:Yea I am thinking that I have a faulty temp sensor, its running at 400 deg now and still switching on and off. I will be taking it apart after it cools down and taking a look. I might just bypass it for now and run a direct line to a switch as we only run it on high.
