I have an englander 30 and am running the single walled pipe straight up thru the ceiling. I have measured the length and even cut a little short. I cannot seem to squeeze the pipe between the ceiling and the stove. What is the trick?
Yep, call the local hardware store and ask if they have a 6" stove pipe slip connector. I saw one in our True Value last week. It wasn't Simpson brand, but this is the idea:
I found that the stove pipe adapter (the piece that connects to the Class A chimney) had about 4 inches of pipe that slipped into the top piece of stove pipe. The top of the stove also had a little extra play. Between those two I was able to squeeze it in, but I also had 2 elbows to help me maneuver...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
