window gasket burning
chrisasst
1,289
cortland ny
I opened my door and a small part of my window gasket is blackened and has a spark on it. Is this a bad thing. Now the piece that did this is a little fraid. Has anyone used hi temp silicon to seal around the window instead of a gasket?
I have an xxv with about 1 1/2 tons burned so far. I have soot on the outside of the door window on the glass. Smoke is obviously making it out through the space around the gasket. It bothers me a little but I never, ever smell any smoke no how furiously the stove is burning. I guess I was just going to ignore it until something that might be a problem appears. I have a buzz also so I thought I'd just ask the dealer about both when I get around to it. I'll be interested in other peoples' opinions. Good question.
clifford
clifford
soot on the outside? get it resealed! also the buzz is likely the distribution fan shroud.....can be fixed as well, all under warrantee.....
I would not be concerned about the gasket having a bit of char on it, as long as it is sealing well. I would not recommend silicone, the stove was designed with the fberglass gasket, I would stick with that.
