btuser
I've got a trussed attic and I still went with r30 batts. I've been in too many attics, rolling around in blown-in insulation. I friggin' hate the stuff.
Yeah, I hear you, foam is the way to go. I would definitely add an air exchanger to the equation, it will really help with the moisture in the winter. My house is 50 years old and I foamed it all and the air exchanger pulls a lot of moisture out and keeps fresh air coming in which is nice, I notice my allergies seem better too. Good luck.ihookem said:Yes, Stephenmoore, I have 4" of closed cell foam in the walls. I have the rim joists sprayed in the basement also. That really helps alot. In the attic between the 8" energy saver trusses I have it foamed shut except for the vents. between the trusses. I also have 20" of cellulose in the attic. I do not have an air exchanger in the house yet. I might have to get one though. I do have outside air intake going to the cold air duct in the basement and don't think it's enough. My windows get moister on them real fast and front door is starting to stick. I have been running the bathroom fans every day for a while and that helps. Later, ihookem.
Hey Sting,Sting said:What are you supposed to do with the old knob an tube wiring? You cannot pull like a fat worm out of the ground, and your not supposed to cover it with blow in insulation?
SolarAndWood said:CarbonNeutral said:HD had halved the price of the unfaced to $10 a pop
Forgot to thank you for that tip. 4 rolls of that unfaced R30 and a couple cans of greatstuff made a world of difference in keeping our lower walkout level warmer and more airtight. $50 and a couple hours well spent. I'll easily save that in wood processing this year.
stephenmoore said:Hey Sting,Sting said:What are you supposed to do with the old knob an tube wiring? You cannot pull like a fat worm out of the ground, and your not supposed to cover it with blow in insulation?
I didn't realize your system was active. I think you are not supposed to cover knob and tube with any type of insulation. Do you have any plans to replace it? I saw an add at an electrical supplier last year for a company still selling all of the old porcelain fixtures. It was quite an art installing that stuff. Having removed lots of it, it's always still tough and solid all these years later. I wonder if our current building methods will stand up to time as well. In Canada the electrical code states that any panel upgrade or signifigant re wire requires the removal of old knob and tube. Merry Christmas.
stephenmoore said:Yeah, I hear you, foam is the way to go. I would definitely add an air exchanger to the equation, it will really help with the moisture in the winter. My house is 50 years old and I foamed it all and the air exchanger pulls a lot of moisture out and keeps fresh air coming in which is nice, I notice my allergies seem better too. Good luck.ihookem said:Yes, Stephenmoore, I have 4" of closed cell foam in the walls. I have the rim joists sprayed in the basement also. That really helps alot. In the attic between the 8" energy saver trusses I have it foamed shut except for the vents. between the trusses. I also have 20" of cellulose in the attic. I do not have an air exchanger in the house yet. I might have to get one though. I do have outside air intake going to the cold air duct in the basement and don't think it's enough. My windows get moister on them real fast and front door is starting to stick. I have been running the bathroom fans every day for a while and that helps. Later, ihookem.
Highbeam said:The blown in will be done in a half hour where rolling out and cutting the rolls is extremely labor intensive in comparison. Consider the edges of the attic near the eaves. There is a taper in that area and you can either stop short with the rolls or cut each one like a wedge. Ugh.
Crazy to think that the blown in insulation will somehow migrate to the living space. Don't you guys have ceilings?
