learnin to burn
Yup, it's out a whack...
Should be setting just below the little hash mark at the bottom of the inactive zone.
learnin to burn said:Yup, it's out a whack...
Do you have a link?Todd said:Get a new thermometer from Condar that has numbers on it.
Hope your right, I move the needle. Means the cat will be in the Active zone for a lot longer times. The temp is now way up in the active zone.
Lanning said:learnin to burn said:Yup, it's out a whack...
Looking at your picture above when the needle gets to about 1 O’clock the cat should have a dull glow to it. I frequently see the needle on mine pointing to the m in Columbus, then the cat is really glowing.
learnin to burn said:Lanning said:learnin to burn said:Yup, it's out a whack...
Looking at your picture above when the needle gets to about 1 O'clock the cat should have a dull glow to it. I frequently see the needle on mine pointing to the m in Columbus, then the cat is really glowing.
Lanning said:Do you have a link?Todd said:Get a new thermometer from Condar that has numbers on it.
