stove cleaning
ad356
156
north java, ny
i would like to use my shop vac to clean my stove after it cools. i tried cleaning it once with the regular filter and it exhales a terrible amount of dust. i mean it was really bad. i was wondering if they sold a filter for this purpose. i have a 6 gallon 3 hp shop vac. i looked into loveless ash vacs and i found they arent cheap. at 250 bucks they are the price of a ton of wood pellets. what do you guys use? i have been using my household vaccum just because the bag doesnt leak nearly as much dirt as the shop vac did, however i realize that is less than ideal.
get yourself a drywall dust filter bag for your shop vac, or get another section of hose and put the vac outside. That should solve your problem.
x1
Get a drywall filter bag...works great and well worth the money
yep, use a drywall filter bag and also a hepa filter (avail on amazon or shop vac website) and you won't see any dust or debris.
I've been using this filter with a standard bag in my shop vac without any issues. I am seriously thinking about shelling out the coin on a loveless for next year though, as it is a pain to shut down the stove for a couple of hours to clean it out. I was going to get drywall bags as well, but they were out of stock when I was at the store.
http://www.amazon.com/Shop-Vac-90340-CleanStream-Replacement-Cartridge/dp/B000093HP2
I've been using a Shop Vac - 2 1/2 gal. 1.5 hp . Works great . Muss
I use a shop vac put a tee shirt over the filter works great just remove the tee shirt and wash it out.
I had the same problem $4.00 was enough to resolve it.
All you need is to get a PVC T , shove it into the exhaust and cut 2 small pieces of any filter media into the ends for a secondary filter that traps the dust.
Here`s a picture of mine:
And another of it attached to the vacuum:
http://www.pbase.com/johnd1/image/100614111.jpg
http://www.pbase.com/johnd1/image/100614117/large.jpg
pellet burner said:
By the looks of the black soot all over the outside of it.....it seems to be letting some ash out.
Nah, it`s tight. maybe 25 yrs old and a bit grubby but this vac has been thru the war.
THE ROOSTER said:
Now THAT is a good idea... I have that very same shop vac and will be trying this!!! One question, do you add any water to the vac, to help trap the dust???
I don`t add water but maybe it would work?
Shopvac with regular bag filter. 20 min after I hit the off button I am running again. No dust no fire no problem. I clean my stove everyday. I don't have too but for only 20 min mitt as well.
I clean 100's of stoves with the same pleated filter and
primary full cloth filter on my shop vacs.
Normally replace the standard cartridge filter about 3 times a year. and the cloth filter when needed about every other year.
Working in customers homes I need to be sure I dont blow dust.
I have been using the same system in all my vacs for 19 years.
http://www.shopvacstore.com/product/0-26282-90638-0.html
[quote author="hearthtools" date="1263721410"]I clean 100's of stoves with the same pleated filter and
Rod, Yours is a much newer design. I couldn`t find a pleated filter that fits my old shop vac. All thats available is the round cloth that wraps into a bag over the foam. However with my $4 modification it works real good but if I was cleaning stoves for a living I`d probably have the best .
If and when I buy another vac it will be one that utilizes a pleated filter. From what I can gather it is the most efficient and as Rod`s (above post with pic`s) illustrates along with the resusable bag helps extend the efficiency and prolongs the cleaning of the vac itself.
I use the blue Ultra filter and a disposable filter bag together. When the bag gets full I dump it in my wife's flower beds.
what I use in not a bag it is Dacron material that stops the heavy partials from plugging up the Pleated filter
fits over the rim of the can
I would go broke if I used the bag type. I would go through 5 a day.
I use the small shop-vac with a HEPA filter. The filter actually costs more than the vac but lasts forever. I am on my third year and the filter still looks and works like new when I whack it against a tree a few times each time I empty it.
I use a craftsman with the blue hepa. On 2nd year with it Works great.
Schoondog
Not sure if this is a crazy idea or it has been done, but I have a shop vac with a 1.25 inch hose and my stove exhaust is 3 inches...anyone see or know where I can get a piece of pipe to attach to my stove exhaust (3") and attach the other end (1.25") to my shop vac and just suck all the crap out?
Try a leaf blower instead. A shop vac on your exhaust will do some good, but a leaf blower is much more powerful, and will clean your stove much better.
Where do you attach the leaf blower?
