buffygirl
We had one back in the 70's - had a comforter stove piped into a fireplace - loved that stove heated the whole house about 1800 sq ft 2 story -- always had the chimney cleaned in the spring by the same guy who just happened to be a local fireman - but one year an acquaintance of ours started a business cleaning chimneys and furnace vents with one of those humongous vacuums on the back of a truck - when turned on fingers popped up - anyway, we decided to give him a try - when they arrived it was two young men who were clueless - well, they cleaned the chimney and left -- that fall I cranked up the stove and suddenly this roar started along with thick black smoke which rolled down the street. Fortunately, I had a chimfex which I popped open and threw into the stove and shut it up but one of the neighbors had called the fire dept. When they came the fire was already out and they didn't do anything. What the chimney cleaners had not done was vacuum the smoke ledge after brushing the chimney. Needless to say, we called the old reliable cleaner and he came and cleaned up after the new guys. Lesson learned - stick with what you know and who you trust.
Then a couple of years ago, we had a fire in the stovepipe which burned thru the pipe - luckily I caught it before it got worse. We replaced the pipe with some heavier gauge pipe and after that started taking it down every month to clean.
