How big a flame is too big?
CFFuts23
9
Southern, NH
We have a Quadra Fire Mont Vernon insert and we are on our 2nd season. As reported earlier, we have been having problems with our pellets - Maine Woods. The pellet type was set to 'utility pellet' per the instruction of our dealer. That resulted in huge amounts of white ash in the burner, with little ash in the ash pan. Dealer then told us to change the pellet type to 'softwood' and the result was much more heat, smaller amounts of ash in the burn area, but signficiantly more black ash on the glass and much more ash in the ash pan (fills up after two bags). While I'm not thrilled about the extra soot / black ash, we have been running the softwood setting since it heats much better.
Now the new problem....over the last two weeks, we have been getting a burning paint / metallic smell from the stove. It smells worse when the stove is running full tilt and we have noticed that the flame is getting really, really high - despite being set on the lowest setting (the flames are reaching the top of the glass and putting soot on the top 2 inches of the pane).
Any advice?
Is it time to call and have the dealer adjust the flame hight setting?
How hot is too hot? If we smell burning paint / metallic smell, does that mean we are running too hot and at risk of a fire?
Many thanks in advance; this is only our 2nd season and I'm still getting the hang of diagnosing issues with the stove.
Really good question because I was wondering about this myself... A lot.
High burn has my flame raging the full height of the burn chamber, I set the firing rate to do that. I'm curious about what the exhuast temp is and how much heat is being wasted. I'd also like tobe able to monitor the heat coming out the front. Really I'd like to monitor both constantly. These darn PS's are like old VWs, you get hooked on dinkering with them lol.
I run my St Croix on 4 or 5 (out of 6) every morning to help burn off any soot... the flame is VERY high...your stove has a high limit switch which will sut it down if the temps get too high.
cffuts23,
Set the fuel type to a hard wood pellet and the flame height to 0-2 the white soot is fine but the black soot is an incomplete burn basically wasting you fuel the maine woods have alot of ash. the soft wood setting does not provide enough air for them to properly burn. The flame height is a user setting that you can change by your self its easy. when setting up your flame height the stove should be on heigh and you want the top of the flames to be around the top of the diamond on the baffle.
The flame on my englander will easily reach the top of the stove on all but the lowest settings. It's not a problem at all. My stove originally didn't have that high of a flame though, until I put some steel wool in the holes on the sides of the burn pot beneath the wear plate. Now my stove has quite a bit more airflow through the wear plate, and burns much better as well.
Bigger the flame the better!, bigger = hotter!
