What the heck kind of wood is this?
albertj03
560
Southern Maine
In the pics below are of a piece of wood I cut from a standing dead tree out back of my house in the woods. The odd thing about this tree was that when I found it there was not one piece of bark on it and there was no rot or holes from Woodpeckers. The wood is heavy yet it is very dry and it's solid as a rock. The trees here are mostly red & white oak, maple (not sure which kind but I think suger or silver), white, yellow & black birch, a little beech (but not usually where I found this), poplar and of course the pine trees. This wood is very stringy as you can see in the pics, more than most of the wood I've cut around here. The wood burns hot, long and leaves little ashes. Region is south east Maine. Anyone have any idea what this wood is? I know it may be hard to tell with no bark and there were no leaves near it since I suspect it was dead for several years. Thanks!
Looks like poplar to me.Have you tried burning any yet?
That's funny because Poplar was the last thing I though it would be because it's heavy and very dense. There are quite a few dead poplars around and they are all full of holes from woodpeckers and half fallen down on the ground. This tree didn't have on woodpecker hole and no rot. I've burned quite a bit of it and it burns great - hot, long and not much ash. Not at all like the poplar I've burned in the past.
Ja, that thin line of heartwood and wide growth rings say Poplar.
Looks like Elm to me, was it really hard to split?
Very hard to split, the wood is hard as a rock. I don't really know what an elm looks like so I'm not sure if there are any around here.
Elm is the hardest thing I've ever split. That looks exactly like the elm I cut. Did your maul bounce right off of it?
Can poplar be really dense and heavy when dry? I've cut and burned some poplar in the past and it's usually pretty light when dry. The weight and density is what had me scratching my had at first.
Yeah saying it was dry and heavy and burns long kinda made me question myself but the grain suggests (to me anyway but I'm no expert) poplar.The 4th pic has a groove on the lower left side in the wood that I have seen on poplar around here as well.I know it's the curiosity but as long as it burns good what the hay right? :)
That is exactly what happened. After I cut it I wanted see the grain so I gave it a nice wack with the maul and it bounced off it! I tried a few more times and gave up because of how stringy it was. I ended up putting it through the splitter.
So elm sounds very likely. I'll looks at some pictures of elm and see if I remember seeing any around here.
I believe that there is an elm disease going around here. I've cut quite a few, just like you described, no bark and very dry. I have my father bring his splitter up so it can be processed.
Standing Popular? I thought popular fell when it aproached dead :) . Looks like just what I picked up ....burning some right now. Was standing dead elm. Popular and elm split completely differently.
The splits do not look like the grain of an elm too straight and not poplar too heavy and dead poplar falls over easily .
Elm will stand when dead and the bark will fall off . I have a bunch like that but the grain is much rougher . Looks a little more like some type of maple to me.
Was it a single trunk or did it go up a couple feet and split into four or more trunks ? Elm splits out into multi trunks very low 1-4 feet and the maple about 5-10 feet up I don't thinks poplar splits off as much and higher in the tree.
The other thing that I just remembered when I put the wood in the pics into the stove is that it takes a little longer to catch than my other dry wood does but once it does it burns very well and provides great secondary burn.
I was thinking elm. No bark, also is likely to be from dutch elm disease.
I am absolutely positive that is not poplar. When we lived in Minnesota , I was given about twelve standing dead trees for firewood. They had no bark and the wood was horrible to try to split. It had strings that went to both sides of the split and each one had to be cut with a axe. It was real good firewood and looked exactly like what you have. I asked the old timer farmer what it was and was told "Swamp Maple" . It looks to me exactly like the swamp maple I had in Minnesota. David
Never heard of swamp maple but there is a lot of maple here and I found the tree not far from a large swamp. The wood does have sort of a sheen to it like some of the maple I have does. In my experience maple isn't stringy and hard to split like this stuff though.
I don't remember exactly but I know it didn't split real low. The bark was kind of peeled off at the bottom.
I'm stumped because Poplar and elm in that condition.......is light , burns fast and leaves no coals.
Just looking at the growth rings and the punky sections of wood says "burns like pine" all over it.
WoodButcher
I've never seen a dead poplar remain standing long enough to lose it's bark. Looks like elm to me. Has that stringy look and a pia to split.
