I
imacman
Guest
CWR said:...... You've got nothing to prove and no affiliation to any one company. I'll take your "real world" testing any day.
Chan
X2 Jay, you da man!
Chan
CWR said:So, in a nutshell, Jay's testing reflects actual use
Webmaster said:CWR said:So, in a nutshell, Jay's testing reflects actual use
By one person, with one particular stove, in a particular house, with particular weather and a particular vent system.
Yes, true.
It also reflects on particular BAG of pellets from on particular batch.
In short, it may be of interest, but I really fail to see how the results can be applied to a broad spectrum of users, batches, stoves, etc.
dobie daddy said:plain and simple. More Fuel=More heat.
Less Fuel= Less heat.
Pellet size has to be accounted for.
Length, width and density
jtakeman said:dobie daddy said:plain and simple. More Fuel=More heat.
How would you do a fair test on all the different brands?
I found it fair to just leave my stove setting to 3 and measure temps. Do you measure all the brands, weight them per pound and see how long the bags last to the exact minute. I think not. Thats lab testing at least. Our lab testing is self policed by the manufactor.
I am doing what the average person does. Loads the hopper sets to there normal burn setting and goes from there.
You forgot one little thing too! The fiber. You see each species of wood has a different BTU rating. Use a lower grade fiber you get no heat. Use a quality fiber you get great heat! Easy to use an excuse about length, width and density. That's why there controlled by the PFI standard. The fiber isn't! Funny how another brand had long pellets too. But there heat was still very good? how can you explain that????
BTU said:dobie daddy said:jtakeman said:dobie daddy said:plain and simple. More Fuel=More heat.
Let me put it in layman's terms 4 u.
Without regards to the material being bamboo or pipe tobacco:
Now if u oppose this fundamental fact, I suggest your biased or misinformed.
You are actually very correct Dobie Daddy, but you are missing the big picture of this testing. As Jay has mentioned on this forum and in his disclosure, this isn't a LAB test. It's what 99.9% of the pellet buying public would see if they were using these pellets in their own stove, give or take a little. This is only meant to be guide and ALL pellets are subject to change depending on 101 different things from moisture, stove, room size, temperature outside, humidity, etc, etc, etc.....YMMV and not everyone will duplicate these results exactly...not even Jay if you redid this test 20 times this season for each pellet....But it’s a great GUIDE and that is how you have to look at it. One pellet is 1/2" on average and the next 5/8", OK so what!!... Joe Six Pack isn't going to make any adjustment to his stove for this...or if he does, he is one in 100,000. Let's be real here...you get a bag, you open it up and you pour it in and away you go and the stove does it's thing.
All Jay is trying to do is figure out which pellets are decent and which are crap...so what if Cubex is 7 degrees hotter than Okies...that isn't a big deal ...but 84 degrees hotter than Inferno’s should be to most people. Having .281% ash is very low...having 1% is almost 4 times as much and should influence somebody’s buying decision....and that is exactly what this test shows...with pictures...
You don't like his test...that fine...don't use it or play attention to it.!!...... ;-)
You don't like his test...that fine...don't use it or play attention to it...but there are literally thousands of people on this forum that will use it and will play attention to it, along with several manufacturers and distributors who find it very useful...flaws and all... I can get all the lab tests I want, but to see what the public will get (even if this is just one snap shot, from two bags of whatever pellet you choose) its IMHO a very realistic picture of what the public is also seeing....the fact that Jay is using a multi fuel stove probably is giving even better results to some of these pellets than others might get with lesser stoves....
I welcome his results, good, bad or whatever...and I think most feel the same way as I do...regardless if one brand of pellet is slightly longer/shorter .......but that is just me..!!...... ;-)
power guy said:BTU said:dobie daddy said:jtakeman said:dobie daddy said:plain and simple. More Fuel=More heat.
I’ve been a fan of this forum for a few months. I’ve found it every informative and learn quite a bit about pellets and stoves but I have never commented before this. This thread has bought me out of the woodwork.
I love my okies but living in a remote area I like to try different brands if my source ever was to dry up. I use Jay’s chart as a guide not gospel. I realize I might have different results but it gives me a guide line since I’ve only been burning just shy of a year. I buy a few bags of different brands and form my own opinion.
BTU….I couldn’t have said it better.
Jay, I appreciate your time and effort!
i agree with you 100%. btu.......... thanks also jay for all the work you put into this. it is a big help. i still am going to test them before i buy the too. and im buying different pellets than i did last year barefoot and okies or hammers.BTU said:dobie daddy said:jtakeman said:dobie daddy said:plain and simple. More Fuel=More heat.
geek said:jay, not sure if anyone mentioned this but wonder if because this test is aimed at finding the Ultra hot pellets, then maybe the chart should be sorted by the hottest temps going to the lowest, what do you think?
jtakeman said:geek said:jay, not sure if anyone mentioned this but wonder if because this test is aimed at finding the Ultra hot pellets, then maybe the chart should be sorted by the hottest temps going to the lowest, what do you think?
Hey geek,
My temps have been deamed invalid! But if you would like I can make a seperate chart listing them highest to lowest. Let me know and I will see what I can do.
Take care
jay
Jim H. said:Jay, quit pissing off people and get back to the testing! LOL Don't listen to they few.....we appreciate the time and effort, and if the "few" actually read your results may vary part, they might just shut up! It is a fair test.....apple to apple in the feed rate etc. Real world as well. I am a set it and forget it guy, but my xxv on room temp makes the adjustments for me.....Keep it up Jay.
Jim
dobie daddy said:I would suggest the parties read the conduct rules located here: https://www.hearth.com/econtent/index.php/wiki/Forum_Rules/
And to all the parties to offer any evidence to disprove my infallible statement "Without regards to the material being bamboo or pipe tobacco:
Less Fuel= Less heat."
and not the same old rhetoric.
Thanks
Thanks
dobie daddy said:Jim H. said:Jay, quit pissing off people and get back to the testing! LOL Don't listen to they few.....we appreciate the time and effort, and if the "few" actually read your results may vary part, they might just shut up! It is a fair test.....apple to apple in the feed rate etc. Real world as well. I am a set it and forget it guy, but my xxv on room temp makes the adjustments for me.....Keep it up Jay.
Jim
Let's see:
I been told to "don’t use it or play attention to it" (meaning the thread) by a party who has admitted that they have monetary interest at stake.
To "Don’t flap your lips!" by a party who said "I am in no way biased in anything I said! "
To "just shut up! by a party who claims different pellet sizes are "apple to apple in the feed rate"
Thanks
