Bill Murray said:Where do you get a propane tank,and about how much? in northern michigan .Do you know the size off hand?
Bill,Bill Murray said:Where do you get a propane tank,and about how much? in northern michigan .Do you know the size off hand?
Fred61 said:WoodNotOil said:Singed Eyebrows said:How many contributors to this forum have 10 years experience operating a Wood Gun? I'm not a guy that's running on autopilot, not aware of what's going on around me. I do analyze problems and make corrections when I'm able to do so.
As far a I can see, there have been no appreciable design changes in the Wood Gun since I bought mine. The air leaks came from the door gaskets which were continually eroding and were almost impossible to keep up with.
It's interesting that when I was replacing center bricks, they were $200.00. It was reported recently that they are now selling for $134.00 and now I see above that they are $100.00. Pretty soon they'll be giving them away.
10 years on the WG post improvements??? Not possible since the improvements are less than 10 yrs old, but I would like to know how often you went through door gaskets. Also interested to know if you have first hand knowledge of the new & improved WG. I'm not doubting anything that's been said by anybody here, just trying to put things into context. For instance, if anybody based their thoughts on the Eko boilers from the gasket problem era you would think it's a boiler to steer clear of but knowing from many users that the gaskets are "new & improved" should keep that boiler on anybody's short list?
It does not matter to me what anybody purchases but it should be clear if comments made on current design/materials are derived from current owners/usage.
muncybob said:Fred61 said:WoodNotOil said:Singed Eyebrows said:How many contributors to this forum have 10 years experience operating a Wood Gun? I'm not a guy that's running on autopilot, not aware of what's going on around me. I do analyze problems and make corrections when I'm able to do so.
No, my Wood Gun would have had old door gasketing. I'm not familiar with the door gasket improvements so I must apologize for my statement that there have been no improvements. My door gaskets had a fiber material with a thick overlay of high temperature silicone rubber which would continually erode. I had the 140 model which meant that I had a few more inches of gasket than you have on the 100. The only place the gaskets didn't erode was behind the smoke plate. How are the gaskets made now?
I have an Eko from the gasket problem era but I don't have leaks. I believe the design of the doors provides a labyrinth that protects the door gasket from direct heat whereas my Wood Gun had flat poured refractory at the same level as the gasket. Also I believe the doors were a direct target for the the hot flame. The experiences I have posted about my adventures with the wood gun were posted to help any potential buyers. If the sales people can convince a customer that the improvements have solved past problems that's fine.
Bill Murray said:does anyone have the dimensions of a 500gal propane tank?
