Dear all - need help from anyone with experience in such stoves or installations.
VC Encore 2550 has recently "shredded" the oval to round exhaust connector that used to join to the 8" flue (vertical) after about 9 years of fires. temporarily fixed with galvanized pipe while I await information on a permanent fix
Problem : I have an alcove installation with about 4" room on each side of stove and 4-6" above.
How does one go about replacing this oval to round connector piece?
1. Do I need to remove the stove from the fireplace first?
2. If so, any tips on best way to "slide out" a 350lb stove? . . .and what maintenance I should do when it is out . . and how best to get it back in?
3. How do you determine if the flue is of the telescoping type (which would make installation of connector easier) without doing any damage?
Many thanks
Many thanks
