How often do you work on your stove?
Question of the day. How often do you have to work on your pellet stove, excluding the cleaning?
  • Total voters
    81
The only repair needed was an igniter replacement. I've busted some minor parts tinkering with it, all replaced under warranty after I told them it was my fault.
feed jams due to long pellets or the occasional piece of foam peanut or metal warning label.(where the hell did that come from???)................ are the only problems.
While I chose "once a year" as my answer for the XXV, it was NOT Harmans fault. I'm in my second year with the stove and had to replace the room temp probe because my cat ate it! Other than that, so far so good!
