Maybe this will work or maybe not need some advice from the pros
kscowboy
99
kansas
I have been posting on here trying to figure out how to vent an add on furnace from my basment using the chimney that is there that goes to the attic but not thorugh the roof the way i have been looking at doing this was using a transition plate to connect the liner to class a in the attic and make a whole in the roof and run the class a out of it BUT HERE IT goES my new thought. How about running the insulated liner clear to the roof mounting the transition plate to the roof and connect the class a directly to it would this work thanks for the help
It would work, but it wouldn't be to code or very safe.
Your first idea is both to code & safe, & is the only way I'd EVER
do what you're trying to do if it was in MY home...
thanks for answering i to was not sure about the saftey part of it i will stick to the orginall plan thanks again
