BrotherBart said:I had a fire night before last but just turned on the radiator heaters today. I have been about as entertained by wood burning for this year as I care to be.
wahoowad said:BrotherBart said:I had a fire night before last but just turned on the radiator heaters today. I have been about as entertained by wood burning for this year as I care to be.
Are you feeling OK?
I've had 3 or 4 fires in the past week. I have one going right now. Wood heat is all we are using any more. It got downright chilly outside. I'm with you- when it gets down to 68-66 inside, I do feel it. Some mornings when I came home late, it was getting down into the low 60's inside. Darn right I burned! That's why I cut, split, and seasoned all that wood. ;-)wahoowad said:66 in the living room, that's when we fire it up! Who's with me?
Where's the 90 degree weather we were having?
Uper said:There's also nothing quite like the dry heat of a wood stove when it's raining and 30-40 degrees outside!
Are you feeling OK?
ColdNH said:wahoowad said:66 in the living room, that's when we fire it up! Who's with me?
66 is cold? most HVAC systems are designed to keep a building at 68-72 degrees. that's only 2 degrees off!
if i burned at 66, i would be burning year round as my basement is typically in the low to mid 60's all year. heck we were down there last night and it was 63, just threw on a hoodie and blanket.
I too vacuumed and polished the stove last week when it was 90. i refuse to start it up till fall! if i need to run the electric baseboard so be it!
