Chimney Shoe Question
leeave96
1,113
Western VA
OK, when you folks are climbing around on your roof to clean your chimney, what kind of shoes are you wearing so as not slide off the roof?
Any tips on scurring around the roof without taking a slip off it to the ground?
Thanks!
Bill
Wear something comfortable and with a rubber sole. I've had luck with the "Skater" type shoes they are made to grip the surface of a skateboard. You can find them cheap and they do a good job of gripping the roof. I've also found that a lot of work boots don't hold up that well on the roof and tend to not be as comfortable. But most important find something that feels good to you and maybe do a test run on a shallower roof to get a good idea on how they will perform.
Stay within your comfort zone and if necessary, use a good safety rope that will limit your fall to the rooftop if you slip and fall. Our roof used to be cedar shake and I would always use a safety rope. Now that it has a composition roof, I can scurry around pretty securely with a good traction shoe. I like a soft-soled shoe for this, one that laces on, not a loafer style. But truth be told, I am getting too old to do this much longer.
Cold and wet can make a soul grumpy, especially if the sole is slippery. I stay off of wet roofs.
Yes, please stay off a wet roof.
While I was doing my mid-winter check of my liner it started snowing, by the time I put the cap back on the roof was already getting covered in snow, that was the scariest experience I have ever had. I always just wear my tennis shoes, but with the pitch of my roof my ankles are killing me from standing at the peak while cleaning my liner, thinking I might try my boots the next time for ankle support.
