Hi again -
I just got a sweet deal - small Buck Stove, $500, never used, from a private seller. It's going to fit in the fireplace, but only with some maneuvering, which means all extraneous
weight has to go until it's in place.
I've removed the door, and started removing firebrick. I'm having trouble removing the bricks, because each piece is silicone-glued in place. I pried off a few bricks using a screwdriver, but
the ones that aren't budging will get their ends chewed up if I continue this way. Any suggestions? Or should I just forget about removing the brick and get a few more people to help me
move the stove?
move the stove?
