Home Made Splitters
negative1
11
MI
Can you guys post some pics of home made splitters. I would love to see some of the innovative ideas that haved served users well.
Thanks
here is an old picture of mine, it now has a log lifter I will see if I can get a updated picture.
My late FIL built this. I re powered it with electric.
This is a splitter I built with some help from friends. I pull it around with my mower and the hydraulics are powered by my larger tractor. I simply disconnect hydraulic lines to backhoe and connect lines to the splitter. Everything was surplus except for cyliner, control valve, and lines.
Sorry it took so long getting back. I wanted to have a pic of my splitter.... along with a little backlog of Ash to split.
I need to cut down about 15 more Ash trees so the backlog may grow.
There are some great home builds here! I really like the John Deere green splitter Jim.
My Grandpa and Brother built this one 20+ years ago. It was a good design when it was built it is way behind the times now. While I still use it it is definitely a pain in the back. It is too low so I am always bent over. It throughs all the wood infront of the axle so you can only split a few logs then have through them out of the way. If it kicked the wood out the back you could just pull the splitter forward from time to time and keep splitting.
Billy
This has been making big logs into firewood for a few years now. Electric start w/log lifter.
Here's mine. Started life as a Didier.
So I guess the big question - anyone want to post plans?
What Plans??
This goes here, that needs to be "this" long. Oooh - a little welding there, cutting here, etc. Or at least that is how I did it. But it wasn't my first rodeo either.
Alright, I'm comfortable with cars and engines - but I'm looking for a howto on making the hydraulics do work. I have zip in the hydraulic experience, so what's the basics of that whole thing? What actually pumps the piston? (I know you're going to say "A pump, silly!" - I'm looking at building one from junkyard goodies, so play along with me).
The simple way to get the "basics" is to look at one at the store. Engine runs a pump (2 stage that your probably not gonna find in the junk yard - and YES - without using BIG HP your gonna need a 2 stage). Tank full of oil supplies engine driven pump (pump is connected to engine via a lovejoy connector). Outbound from the pump to the control valve (the lever you push forward and reverse). This valve needs to be an open center valve. What that means is that unless the lever is in a forward or backward position, the oil flows through it - no pressure (or little) and returns to the tank. This valve will have 4 holes. input - output (to tank) - one to the back of the cylinder to push forward, and one to the front to push it back when the valve handle is moved from the center position.
We talking lawnmower two stroke or we talking motorcycle two stroke?
We talking 2 STAGE - if you are referring to the pump.
Sorry I misread. Stupid question time: I googled for hydraulic piston to try to figure out what I'm looking for. The answer is that there's a million of them all of differing specs.
What should I be looking for?
How big of a splitter are you trying to make?? You can consider the components a "matched set". As an example 4" cylinder/ 5hp engine/11 gpm 2 stage pump...or..... 5" cylinder/ 8hp engine/16 gpm 2 stage pump, etc.
For the cylinder you should first decide what kind of pressure you want to create. A splitter for 14" lodge pole pine can be built different than a splitter for 48" elm. Then length - although 24" stroke is probably the most common. And you will more than likely want the clevis type connector on each end (think draw bar on a yard wagon)
Thanks for the link, I'm probably going to make something which is driven off one of the cars. My wife will object, but the jeep cherokee she dearly loves has mechanical pulleys for all the accessories so it's a reasonable candidate for MORE BELTS!!! (Then again I just finally got the woodstove settled...)
Anyway if I'm going to make a splitter I'm going to set it up to destroy the world. What's it take to split elm?
I would recommend a 5" ram for elm. It won't stop and if built properly, you could put a 4 way wedge for the less nasty stuff. I don't suggest using the wifes jeep for the power plant. Running a large and more expensive engine to run a splitter is probably not the best bet. A $25 used 8hp briggs from an old lawn mower will work just fine.
How do you feel about electric log splitters with four tons of pressure? How many tons of pressure are we talking?
+1, I replaced a 4 cylinder gas motor out of a bobcat with a 5hp electric off a rotted compressor and am much happier.
If you don't have a few of the major parts, such as motor, pump, cylinder, valve, and reservoir. It may be cheaper to buy a used one than to build your own.
4 tons, USELESS! Don't waste your time or money on it. 15 tons minimum.
Forget the idea of powering a splitter off a vehicle. Take the advise above and find a cheap used engine if you're on a budget. Mine is now powered by a 5.5 hp honda and it sips gas. Takes well over an hour of splitting to go thru a tank of fuel. Seems like the tank is the size of a shot glass. The initial expense of the engine will be paid back quickly in fuel savings when compared to what you'll spend running the jeep engine.
