opinions on installation of the woodstock fireview.
RIDGERUNNER30
236
Eastern, Kentucky
In the next month or so I will be installing the fireview in my main living room. I was going to install in the corner of the room, but now I have talked my wife into moving stove to the center of the room . my question is the owner's manual says that the minimum hearth pad size can be 44in D x 50in W, but is recommended to be 48in D X 60in W. I need to use the minimum hearth pad size because of my room being so small it is only 12 ft wide and 16 feet long. my plans for the hearth pad are as followed,framing with 2 X 10's and two layers of 1/2 in durarock to give me a 12in raised hearth and having 1/2in durarock and slate tile on the pad and behind the stove with a 1in airspace behind the stove so i can get the stove pushed back as close as the specs will let you which is 12inches, but anyway my question to fireview owners will this stove roast you out of a room? The sofa in this room we be about 6feet from the stove and i worry sitting on the sofa with a fire going will roast a man out there they are two bedrooms that are on the right and left sides of the living room giving some place for the heat to travel and these rooms I will mostly keep the doord open on them they are my kids rooms. what do you guys think I have got to make this thing so give some advice.
Well I sit at the computer 7' from side of mine. Also have the end of my couch 6' from the front of the stove and everyone fights for that spot. It gets warm but doesn't blast you out like steel.
Good deal, Thanks todd for advice i was a little worried that it would blast me out of the room, I have a steel stove in my den room that is located in the back part of the house and the fireview will not have run hard just enough to keep the bed rooms warm.
I agree with Todd, I have an L-Shaped couch. The stove is in the center about 8 feet straight across from one couch of the sectional and I sit there to watch the fire, it gets warm but not HOT HOT HOT..then the other corner of the couch is about 6 feet off the front and side of the stove. That is where the wife sits....I don't even argue anymore. It is warmest right there, but not so bad to run you out.... by the way, on the side with the loading door, add as much extra hearth as you can on that side....this will help you out while loading and makes it safer for popping wood when reloading.
Funny thing about that rear clearance requirement. Are you venting straight back through the wall or are you going vertical inside the room? If you are going vertical then your double wall chimney must still be 6" from the wall regardless of what you tile it with.
I foudn that the fireview suffers with regards to rear clearance requirements. It makes up for it somewhat by such a small requirement out front. I way oversized my hearth on the sides of my sideloading stove and have really been glad I did that.
