Grassman
It is true that ag. energy crops draw a lot of unwanted elements from the soil. Most of witch have to be dealt with when burned and the temps rise above 500 F. One of witch is Cl, it becomes a aerosol bonding with H and you have a spray of HCl going up your chimney. Luckily there are stainless alloys that can resist these acids. We use field retting to wash out the elements that will cause problems when burned, by leaving the cut grass in the field for 30 plus days and hopefully letting 3 to 5 inches of rain wash the grass. By doing this you can greatly reduce the elements in the fuel that will cause corrosion in your stove and chimney. Cl is highly water soluble and is easily washed out. But as mentioned in previous posts always be safe check your chimney and stove to be sure that they are made of materials that are rated for ag. fuels. DJ
