Jotul 602
My Oslo heats my home
1,584
South Shore, MA
After looking at the prices to repair and replace parts on my backup stove, over $350(Dutchwest 2461) I have opened up my options
for a used Jotul, preferably a 602. The space is limited from the rear wall and this stove has caught my eye.
commenst, criticisms?
D
The 602 is a great little stove. More of them have been sold worldwide, I believe, than any other wood stove. I use mine at this time of year and in the spring when the big Firelight is unnecessary. The only drawback to the 602 is the tiny firebox. This means the wood used has to be quite small and you need to frequently empty out the ashes. On the plus side, it puts out a lot of heat for its size and it heats up very quickly. This last quality is just right for chilly mornings when you need some warmth for just a few hours. My 602 is over 30 years old and remains in great shape - it has, admittedly, seen very light usage. Whether more recent EPA certified 602's are as easy to start and operate is another question.
I've had my 602 for 3 years now (although its being replaced this year by my brand new PE T5!!), and it was a great little stove. It was used to heat my basement (Man Cave) for the last couple of years, and did pretty well. My basement was a 800 sq ft, uninsulated, with a stone/block foundation and got to be as cold as 52* F on the coldest days/nights. The stove was able to raise the room by 20* within a couple of hours, however I had to run the stove hotter than most would like, as I had stove top temps read from my thermometer of 700-750*. Would do better this year, had I kept it, as now I sectioned off two of the four walls in the basement and insulated those walls, making the space around 600 sq ft now. Its now sitting in my garage next to the T5 awaiting its new home.
the stove burnt well and burnt anything you put in it. Not sure if it was solely the draft i have or the stove or both, but that sucker took off like a blow torch when started up with paper, kindling and a few small splits. From there I would put in 3 splits (16" max -- what a pain in the rear trying to find someone to cut splits that short around here) and close the air down gradually, until it would cruise for about 2 hours or so. Then I'd increase the air gradually before starting the process all over again. Constant tinkering with the stove with loading, reloading and air adjustment, but I never minded that, as I only used it when I used the room so its just something I did during commercial breaks from the games i was watching!!
Begreen and Precaud had/have this stove and they were a big help to me when I first got it. There is a thread titled "Jotul 602 ins and outs" which i started back then and there is good info from guys in that thread about it. If the 602 is the route you go, you won't regret it. Fun and easy to operate.
I have an older model 602 and burned it for years. It heats up quickly and throws alot of heat. I didn't burn it through the night.Smaller splits work great. I an actually going to post my 602 up on craigslist soon. I live on the southshore also. If you look at any 602 watch out for cracked rear piece around the stoves outlet collar. prone to cracking.
I agree with you on many fronts Frax. Firstly, congratulations on the firelight, I'm a Jotul fan from the get go. If my Oslo had as many years as your VC I would be right back to another Jotul in a snap.
Originally I was looking into the Jotul 'bear', but the size was too much for the space I was looking to heat, not to mention the size. I needed a smaller stove.
I likeed the look of the 602 and it would fit nicely in the space I was using. I too use the secondary stove on "light" burning days (spring and early fall), days when I would light a full stove in the morning and then let the sun catch up by mid day and then a slow burn in the evening.
Now all I need to do is find one, used at a reasonable price.
Thanks again for your experience.
Darrin
raidernman, I appreciate your comments and criticisms on the 602. I don't quite have a man cave just yet, but I do have a breakfast room with an existing stove that needs to be replaced. By any chance is your 602 for sale?
Let me know, thanks....
Thanks for your comments Matt, let me know if you are interested in selling... I'm on the SS , MA too
Darrin
I think my brother-in-law is going to take it for his shop. He runs a chimney company out here and pulled it out for a homeowner who had gotten a new wood stove. So he gave it to me for my basement. When I bought the T5, I asked him if he was going to give the Jotul to someone else and he said he was thinking of putting it in his shop for work.
If that's not the case, and he's looking to sell it, I'll definitely let you know.
Darren, I posted my Jotul 602 on craigslist. The stove is in good shape. No cracks in the stove. It has a green enamel finish. The burn plates are in good shape. I made a baffle plate for the rear of the stove. I used it for several years and it worked great. For a little stove it throws some serious heat. I have it on craigslist for $245.00 but I will take $200.00 I think the price is fair for the stove.
Thanks
Matt
We have the 602 in the kitchen which is on the back of the house. It is the clean burn model about three years old. It is a very easy stove to use, except you need small splits and the burn times a short. But when its burning it puts out a lot of heat. It will heat the kitchen and 1/2 the house. We actually use it at times to cook on. This years attempt will be waffles we inherited my wifes grandmothers waffle maker it will fit exactly where the burner plate is. I'll get some pics it's way cool errr hot! :cheese:
Thanks
Matt
Hey Matt,
Can you do me a favor and e-mail the specifics (ie: age, repairs made etc) of your stove and maybe a few pics. I am interested, just want to do a little research first.
Thanks,
Darrin
Darrin,
I don't know the year of the stove. I think it's from the 70s. I don't know how to tell. If you do know how to tell let me know. I haven't made any repairs to the stove. I made a rear baffle because of info I read on this forum. The enamel finish is chipped on the rear of the stove below collar but other than that it's in good shape. I don't know how to post pictures. I will try ot figure it out. I am located in Carver
Thanks
Matt
Matt, did you mean a rear heat shield based on the info I posted? That is different than a rear baffle. It doesn't deflect the flame path like a baffle, it creates an inner heat shield the same as the side burn plates in the stove. Darrin, this is a good idea, with the older 602. From what I can tell, the new models have an air channel in back that effectively protects the back.
