What type of fireplace do I have, and what can I put in it?
kgrant
186
Fairbanks, Alaska
I'm thinking about installing either an insert or a free standing stove in my fireplace. But I need to figure out what I have first.
The fireplace itself is 37" wide, 30" tall, 26" deep. It is lined with brick, on the bottom, sides and back. The top of it is a steel damper. It has an ash chute in the bottom. It has a Thermo-Rite door on it.
I'm know it is original to the house, which was built in 1968.
I know I will need to install a liner and insulate. I know I may have clearance issues with my mantle. I know I will need to extend the hearth.
House is about 1600 sq/ft, moderately insulated. The fireplace is near the middle of the house, so there should be a pretty good chance of heating most of the place with the stove.
I would like to do a free standing stove, but would consider an insert.
What would you do here? What information am I missing?
Thanks!
Here are a few pictures.
Is that a pre fab fireplace, or a masonary?
Built into the house in 68, it's definitely a masonry (site-built) unit.
You have a bunch if options & it's gonna come down to what you
can afford, what you want to look at & what will fit.
To heat your moderately insulated 1600 sf, (I'd say 40 BTU per = 64K)
you're gonna need AT LEAST an 80K BTU Input unit, probably more.
There are a number of inserts that are close - Regency I2400M (& Hampton HI300),
but they're both 75K & 77% efficient (~58K).
There are big stoves, as well, but you'll need a rear exit to get in there & the height of
the horizontal flue collar will have to be taken into consideration.
I'm thinking the Jotul F600 Firelight might be a good choice,
but it's gonna be a tight squeeze & you may have to modify the legs.
I'm sure there are other stoves available, the Hearthstone Mansfield & Regency F3100L
are BOTH 80K units, but they're also top exit only.
Good luck...
No one else wondering why you have Christmas lights hanging over the fireplace??
I can't help on the specifics of which stoves would fit and such. But I *would* like to put a plug in for a freestanding stove as opposed to an insert. I started out with an insert with surround panels, and wasn't happy with the amount of heat I was getting from that setup; eventually made some modifications, see - https://www.hearth.com/econtent/index.php/forums/viewthread/13710/P0/ I know there's been a lot debate about the merits of freestanding vs. insert on this forum; I'll just say that I strongly believe that surface area is key to getting the radiant heat I know and love. As far as brands go, a friend of mine has a Jotul that works well and is simply beautiful. I'm jealous.
Good luck with your project.
I have no idea if it's a prefab or a masonry. What are some good ways to tell?
I'm not a huge fan of cast or stone stoves. I have a BK King in the shop. I think a Princess would go nice in here.
I'm in Fairbanks, which is right next to North Pole, it's Christmas everyday! Nah, actually they're Halloween/fall decorations. You can just see the bottom of pumpkins on the mantle.
Thanks for the input!
Sounds like you're ready to speak to the local BK dealer about a Princess for that spot.
Bob, you're saying that since it was built in 68 it is defiantly a masonry unit. Are there any other ways to tell if it's a prefab or zero clearance (what's the difference between those?)
Thanks
Hi Kgrant,
I think you better get in touch with your local hearth dealer, so they can go and give you an “on site” evaluation. This is important since it will help you in figuring out your precise needs, not all inserts can go into prefab zc fireplaces. I do believe Daksy is right, but I would have a certified installer taking a look at it before start shopping for a unit. Let me know if you need some information on dealers in Fairbanks.
