I have an Quadrfire Isle Royale purchased January 2009 to replace a Vermont Castings Resolute Acclaim. The stove feeds into a chimney about 30 feet high, where the flue lining is about 7 inches square.
When my Isle Royale has a medium load of wood, it will show 700-800 degrees on my griddle thermometer. I have been surprised that at this this temperature, I can set the air control to minimum (far right) and the temperature will not come down until a significant amount of wood has been burned. There are times when I would like to drop the temperature back a tad, but since air input is on minimum, I have no way to do this.
With several other stoves I've owned, I have always been able to control the air input to reduce the stove temperature while still achieving secondary burn.
I want to be able to reduce the temperature at times to achieve a slightly longer burn, but primarily because I feel that operating the stove so hot gives little margin for something going wrong.
Is this how your Isle Royale operates? I am wondering if I need to add an external damper in the stoves connection to the chimney flue to have more control.
PaulF
PaulF
