Phatty
pull the impingement plate brush and vac the whole inside
off to the left in the back is an opening that is where the exhaust
goes. i took the end off my vac hose and jammed it in that hole
and turned it to the right and bang on the stove alittle. i did this with
and emty vac and got a coffee cup full of ash. if u stick your hand
over the top above the hole its half open on top
also in the burnpot on the bottm you can see a nikle size holes
in the lower rear corners put it over those holes and scrape the
sides of the burn pot ash does get down those holes and can restrict
the opening. while in the burn pot i put the vac over the the oak pipe
for a sec just to make sure its flowing air. hope this helps
