Does wood "season" over the winter?
kubes14060
16
Western New York
Just curious...I have wood that I think is close and want to burn it in the colder spring months at my cabin. We are not there in the winter. What do you think. Right now it is covered with a tarp.
In my opinion, no. Seasoned wood needs "Seasons." The rain of spring, the sun of summer and the wind of late summer and fall. Let it sit there for the year and you will be glad you did.
I have always assumed the freeze thaw cycles in winter and the dry air would speed drying. I however have no proof
Guy
yes it does
yes freeze dries.
here i am last year trying to show my youngest boy how to drive a loader at the sewage plant where i work...
and ya thats human waste that came out of the centrifuge which is around 22% solids but over the winter that other 78% "water" turns into about 70% so yes i am thinking wood would freeze dry for sure ;-P
sorry about the crap i just put up :cheese: but figured it was a pretty close example of moisture loss from freezing
loon
now there is a load o chit
You won't get any crap from me, just years of experience. The wide temperature swings in Winter "dehumidify" the air and everything else.
Since you live in western NY, you will find that during an average winter that wood drying will slow very drastically in the winter.
Wood can definitely dry in the winter, but how much depends on where you live. In winter you can get very low relative humidity during the day, especially if cold arctic air moves south and warms up. Low relative humidity and wind can lead to good rates of evaporation and good wood drying. The problems with this include wood covered in snow and places where the relative humidity is high. I think western NY has both. I am not too far south of you in central PA, and we have lots of cold, dry, windy winter weather that quickly evaporates the snow from my wood stacks and I am sure dries out the wood. Not far north of here you enter lake effect snow belt, and I think they probably get a lot less drying of firewood in the winter. You results will depend on where you are. PLus, wood covered in a tarp isn't going to evaporate much water. Snow cover would be just as bad, or worse.
Depends on what you mean by "season." Lots of fuzzy thinking there.
To me it means some combination of three processes: decomposition of plant nutrients in the wood, evaporation of inter-cellular water, evaporation of "bound" intra-cellular water. With emphasis on the former.
Answer: possibly. Temperature is important, as is protection from rain and soil moisture. (Tarp should divert moisture away from wood, not down through it.)
Rate is unknowable from here; size of splits is your control input here.
There was a long, long debate about the relative importance of temperature vs. humidity on this site a year ago. The evidence says that wood will continue to dry in the winter, but not as fast as when temps are warmer. The lower the humidity, the better, but higher temps contribute more to wood drying.
Ahhhhh Yes, the Rain of spring is needed. This is exactly why wood never drys in Arizona. %-P
Ok I am gone now.
Cheers.
In winter the relative humidity can be rather high, it's the absolute moisture content that is low. For much of the country (including NY and PA), wood reaches a lower EMC in the spring than in any other season. That is because the RH is lowest then. This is true, in spite of our famous "April Showers".
Oh... firewood will definitely dry during the winter. This hickory was cut from living trees last December. The photo was taken after it had been stacked outside for about a month. There is some oak in there, too. As you can see, it didn't fare as well as the hickory.
My opinion: Yes.
kubes14060 said:
Does wood “season” over the winter?
Yes. Wood is always 'seasoning' as time marches on. And time is the single most important thing splits of firewood need before they are ready to burn. But wood 'dries' less in the Winter than it does in Spring and Fall during the sunny, windy, warm, dry days.
If you don't want the wood to dry out put chapstick on it.
Maybe some moisturizer, too.
I agree. It will dry some during winter but the best drying is during the summer months.
Temp swings, freeze thaw- those are not driving the drying. Freezing cold slows drying- so it's drying slower when cold. That is a fact. The dryer air helps a bit.
The real answer- it does dry. It dries faster in warmer months.
In my limited experience, if the wood is frozen, it dries very, very slowly. Last year I was given a load of punky maple that that was rather wet, and I just wanted to burn it to get rid of it. Even when split and tops covered, it did not dry much in the dead of winter, with all the water inside frozen. But as soon as daytime temps started to get above freezing, that stuff dried right out and it burned well (we get alot of wind here). Water will go from a frozen state to vapor, a process called sublimation, but it occurs at a much slower rate than evaporation from liquid state.
Move it into a dry basement...the parched air will suck the moisture right outta there.
I keep about 3.5 cords in the basement.
Don't think my wife would let me stack 3.5 cords in the basement family room!
Would she be cool with storing it in my basement?
If you remember George in Seinfeld, he had significant shrinkage in the cold water. I believe it drys year round, it probably won't dry if you get ice on it. But the wind is still doing a number on the wood.
Agree. Think about Bourbon, if any of you are fans. they say Kentucky is the best due the drastic changes in 'seasons' ie as the temp and humidty change the whiskey is forced in and out of the wood barrels. (out in cold and in when warm) while i dont kow about cold months and water traveling in, it certainly would slow the whole process down a bit. I read a post earlier in which people discussed putting wood by a fire to dry. if winter time was better for drying then why wouldnt that discussion have been about putting spilts in the fridge?
