fred is that you?Hardass said:How old is your boiler(when was it built) Did it come from Montana Stove Works or some where else?I have built Seton boilers for the last year, no boilers are sealead on any of the doors, draft or feed.Though i learned a"lot in the last year i am still quite new to the boiler industry.As you see i am also new to this site and here to try and learn more about what is happening out there.
I am a"slo looking for all sites on boilers that have good or bad to say about the Seton boiler so Any info would be help full. Thanks.
you should be the tech line rep. perfect! i love it. the only reason i sealed mine up was for the storage. with my f-upped work hours i need a non fossill back upISeeDeadBTUs said:Trzebs13 said:And the other thing I have noticed is that with warmer days and espessily if you don't have dry wood, this can become an issue. Get that thing cleaned out and start over. Put samller amounts of wood in it than you have been and start from there. I have noticed as the temps are now dropping and the demand for heat is going up this has become less of an issue for me. I haven't found a great way to check for leaks as well, tried using a cigerette and still can't say that I could tell. Do the best you can is about all I can say.
This is one issue that I think storage would be a huge benifit. And I think that it would help the huge temp swings you can get with out it.
Do not put visibly wet wood into the CC. No snow, no ice.
Always put a layer of quality wood on the coals.
Do not load until coals are 1" below air inlets. ans water is below 170 °F
Quit lookin for air leaks.
If temp swings beyond set points, figure out why.
Screw storage. Instead, load appropriatly and start 1 fire a year.
Yup, I know I'm repeating myself. I'm a prick that way. Sooner or later you'll get it :smirk: For the sake of your sanity, I hope it's sooner.
If I had a dime for every time I tried to extract ashes without killing the fire in this beast while I was strugling up the learning curve, I'd be rich. Now, I'm taking out ~1Gal/wk while not disturbing the fire.
Rock on!
Trzebs13 said:Mostly correct once agian. In fanticy land we could always wait until the fire is almost burned out and temps would stay above 170. Here in the real world there is such a thing called life. Lets see, a guy gets up in the morning, looks at his boiler and the water temps are down to 110. He opens the door and see's a good amount of coals. The 1800 sq foot of infloor is calling for heat, which the boiler will never keep up with just coals in the bottom. What does he do? Go wright another post on Hearth.com? Nope he rakes the coals to the front (away from the air intake) chucks the thing full of wood and gets his azz to work.
Trzebs13 said:quote]Do not put visibly wet wood into the CC. No snow, no ice.
Rock on!
ISeeDeadBTUs said:Didn't the old Setons (and I believe the GreeFire) have holes in the bottom of the primary CC for ash to drop into a pan?
If so, why did Seton change that design?
