Which Splitter?
they are one in the same, Brave and Iron Oak are the same company or sister companies at least and according to Braves web site their Iron Oak is their commercial grade product
http://www.braveproducts.com/ourcompany.php
I have looked at both pretty hard this week. I would have to say, for a tiny more amount of money (almost) the Iron and Oak gives you a better hydraulic fluid capacity,
which will help the life of the pump and cylinder over the long haul. I also like the color, and the add-ons are cheaper for some reason (like the log dislodger which should be standard)
I would have to say this is the best price on a full-beam V&H type Iron and Oak 22-ton with the briggs engine I have seen:
http://www.woodsplittersdirect.com/product_info.php?cPath=2_63&products_id=227
free shipping to boot.
Iron & Oak builds amazing splitters. I rented one this past spring and also had a 25-ton MTD on site at the same time. The MTD was a toy compared to the Iron & Oak.
jlove, that looks nice and all BUT for $1800 you could buy two Huskee 22-ton machines. For that money, Iron and Oak should throw in a little garden gnome to scoot around picking up bark and other debris!
S
S
yup and the Huskee has a longer cycle time and the fluid temps are going to be higher, and the foot is smaller opposite the wedge, so you get what you pay for.
The only reason the Huskee has been recommended so much is because many ppl have gotten a discount on it.
I'd rather have a used commercial splitter that didn't have a vertical shaft pushmower engine...
Really, 12 vs. 14 seconds? Don't forget, that's only for the complete throw--if you did half that on a regular basis (reality) than you're looking at 1 second difference. Not sure that's worth $800. BUT, I do understand about the 'get what you pay for'; just sayin'.
S
S
That's just one factor. Here's my main factor of spending extra:
There are two ways to solve overheating problems in hydraulic systems: decrease heat load or increase heat dissipation.
Hydraulic systems dissipate heat through the reservoir
The Iron and Oaks hold twice the amount of fluid as any 'consumer' grade splitter. That prevents heat-related issues, which lead to long life.
The ENGINE on a modern splitter doesn't mean anything. It's all about the weakest link, which, in a dual-stage pump system, is capacity.
Beware of advertised tonnage ratings and cycle times. When cylinder bore, stroke , and rod size are the same, and using the same GPM pump the at the same RPM the cycle times will be the same.
The OP wanted to know the diff between two specific splitters. Here is the basic differences
The Brave VH0622 and the Iron and Oak BHVH2202 have the same pump rate, same cylinder, and are from the same parent company.
The I/O is built beefier with a larger reservoir, and it is advertised 2 seconds faster 'approximate' cycle time. They cost about $150 more than the Brave.
The Huskee/Speeco has the same cylinder, same 11gpm pump, but the smaller fluid capacity and the verticle shaft throwaway engine is a cost-cutting move.
It's cheap, sold at a big box, and you might get a good deal on a returned one
Hi Everyone,
My name is Mike and I am the owner of WoodSplittersDirect.com
I read several forums but I dont post much. I just thought I would chime in here a bit. I just wanted to mostly tell you my thoughts on the Iron & Oak splitters. I have read several log splitter vs. log splitter threads and people generally seem to be pretty happy with what ever they ended up buying. A good portion of the reason is because we all cant afford to buy 5 different log splitters and try them all out or the stores dont really demo their units. So people by one and they really dont know the true difference because they have never tried or even seen a splitter that is $800 more. They see the price tag and a picture on the internet and cant really see the difference to justify the cost.
I get the question every single day why should I buy a $2000 22-ton Iron & Oak when I can buy this "imported" splitter that is 37-Tons (allegedly) for $1250? Or I can buy this department store splitter for $XXX and its the same thing etc... Well they are just not the same. I always use the comparison of cars, most any car will get you from point A to B but there are thousands of different cars with different purposes and options etc. Some as we all know last a lot more miles then others do. Some are faster some can pull trailers up grades better etc etc etc.
Same with splitting wood. Some splitters are faster, some are heavier duty and bigger, some have all American parts, some have no name unproven imported parts that dont last as long etc etc. So it comes down to your budget, what kind of longevity your trying to get out of a splitter, how fast you want to split a piece of wood etc.
Personally I have tried a lot of splitters. We carry several different types and models and 1000% hands down MY personal choice is Iron & Oak. I have put together several of the units, the quality and workmanship and the heavy duty double walled beam, the Prince valves, Haldex Barnes pumps, horizontal shafted motors etc etc just make these splitters absolute tanks. Just the crate it shows up in is impressive in its self. If you look at rental places most places I have seen all use Iron & Oak splitters as their rentals. I have never seen a imported splitter being used as rentals. We have been asked several times to buy and carry larger imported splitters, and trust me I have thought long and hard about it. Even though I know we could move a lot of imports just based on price alone we just don't want to do it. We carry the compact electric imports but that is as far as we are going to go until we can find a good American compact electric.
Again my intention of this post is my personal thoughts of the Iron & Oak compared to other splitters. If your looking at splitters, do your self justice and try to compare them. If you were to line up several brands together I am confident in which splitter would catch your attention. I know which one has me sold. But there is that one small thing that always seems to play a key factor ................ you got it, Money!
Thanks for reading,
Mike
Thanks for the reply Mike. I have experienced using quite a few borrowed or rental splitters, since my father used to work for the now-defunct Rental Tool and Equipment company in the 90s.
Two of my friends own splitters that are AT LEAST 25-30 years old (one a montgomery ward repowered w/ a Briggs 11hp and the other a northstar that has been repowered and re-pumped once )
The build quality of each gives me something to base my opinion of a splitter just by looking at it.
I also have a friend who purchased one of the recent Northstars by Northern Tool. It leaves something to be desired in the build quality department, but the hydraulics are decent.
I notice they have since beefed up their entire line. This one doesn't have a mechanism to lock it in the vertical position, and is (to me) a dangerous oversight. I also bent the log dislodger on a piece of sycamore, which shouldn't happen.
When I started looking at the Braves, I noticed they were alot more for the same money. Then the Iron and Oaks are a step beyond that for a little bit more. I believe in buying power equipment to last a lifetime if possible nowadays...
I do have a question for you, what do you think of the newer short-beam units. I notice everyone from Troybilt to Brave makes one of these for consumer grade splitters.
What are the advantages or disadvantages to this design?
Short beam splitters have been around for a long time. Powersplit, TimberDevil, SuperAxe. Wallenstein, MTD, and others. The advantage of a short beam is that it flexes less than a long beam of the same size, allows for a more compact design, and lighter splitter. Disadvantage is that they require a custom made cylinder, require greater attention to design details, and a more presision assembly.
MTD would be at the bottom when it gets down to quality of cylinder design.
MTD = troybilt, cub cadet, yard machines, bolens, white outdoor. Basically anything sold at home cheapo or lowes-t.
I looked at the troybilt 27-ton at lowes the other day, and it was disappointing. It has a built-in cradle and log dislodger, but they are pretty flimsy looking.
After I bent the one on my friends Northstar I started noticing that particular aspect of design. Sure it beats hitting the logs off the wedge with a sledge!
But they are there to protect the splitter also. Protection shouldn't bend IMO.
Also I was suprised to learn that the Huskees were built by Speeco. When I get a chance to drop by TSC I will try to go over there. I am fortunate to have
a Harbor Sheight, Northern Tool, TSC, Lowes and a few other stores just up the road from me in Concord. Come tax time, I will be making a purchase of hydraulic proportions!
Hey Mike,
Welcome to the forum and thanks for the information. I did notice the local HD sells MTD and Ariens but rents Iron & Oak. Still a tough pill to swallow in the price department, though that's because I scored my Yard Machines for $430. Cha-ching!
S
About the short beams... To be honest I am not real sure about them, nor am I a huge fan of them. It is a cost and weight saving feature that is for sure but as far a performance I can not really comment on it yet. We do sell the Ariens Splitters and they are the short beam design. They are just a standard I beam most lower cost splitters use. These beams tend to flex quite a bit more. Iron & Oak does have the shorter beam on the EZ split 15-Ton and we have sold plenty with out any issues. So I cant really knock the short beam as far a performance as I haven't experienced issues with them. I think its ok on the lower tonnage splitters but not sure on the 25-34 ton splitters. That is where you get the most stress on a beam when you get into the 4.5 and 5" cylinders. But when I look at the beam between the Ariens 27,34-Ton and the Iron & Oak 20,22,26,30,34-Ton it again is a "no brainer" for me as to which is heavier duty. But again the Ariens is about $500-$700 cheaper but it has a long cycle time and less quality parts etc... But it is American made! Again its all about your budget and wants/needs.
thinkxingu - Thanks for the welcome. Well I guess that tells you something if a store sells a couple of brands and only rents another brand and not the brand(s) they sell.... I am guessing with the longevity and rental abuse the other splitters dont hold up as well.
Mike
Maybe 'cause it didn't directly answer your question, but I'm surprised nobody mentioned Timberwolf splitters, made in Vermont. I just bought one after much research and advice from local sawmill and firewood dealers.
Not cheap by any means but a very tough impressive machine. Should last me the rest of my wood burning years.
Okay I will offer an analogy:
MTD = Chevy/Ford
Huskee/Speeco = Toyota/Honda/Nissan
Brave/Iron Oak= Lexus/Acura/Cadillac
Timberwolf = Maybach/Bentley and priced like one
Haha.
I've never owned anything but Toyotas, so I guess my Huskee was the right choice.
Nic36 said:
Haha.
As long as it doesn't automatically stick in the extended lever position you'll be fine :)
just watch those pesky floormats ;)
Yep, a runaway wood splitter would not be good.
MTD = Chevy/Ford
It's appalling how you relegate American cars to lowest-quality status. I guess you haven't seen recent quality surveys, including JD Power, which rated Ford and Chevy over Toyota.
MTD = Chevy/Ford
You must be a UAW worker lol. I own GMs and Fords, and JD Power means squat when you speedometer breaks after 75K miles on a $40K truck (GM recall...)
And here I thought Cadillac was an American car?
