I have a FARM BOSS with a 18 inch bar. When i bought it the dealer said he would not recomnd putting a 20 inch bar on it. I would like to put that size bar on it. Is this saw capable of doing that
Backwoods Savage said:I could have put either a 18" or 20" on ours but instead put a 16" on it. I just thought a 20" might be a bit much for that saw.
Roscoe Picco Chain said:You should muffler mod the 290 for a bit more power... at least turn your USA muffler into a Euro-spec: http://www.treeworld.info/f40/ms-390-fine-tuning-questions-12382.html
The MS290 has the same oiler as the 390 so it should be capable of oiling a 24" bar, according to Stihl.
I expect you'll want to stick with .325 chain if you're going to try to get a 290 to run a 20" bar.
joshlaugh said:I second the idea of a skip chain. I run a MS 310 right now and will throw a skip on that to help it pull a 20"bar and chain
gilly1726 said:I have a FARM BOSS with a 18 inch bar. When i bought it the dealer said he would not recomnd putting a 20 inch bar on it. I would like to put that size bar on it. Is this saw capable of doing that
smokinjay said:It can be done just need bar and chain. Half skip or full skip will let you pull a 20 in fine! Bigg Redd favorite!
burr said:I own a 310 (or 031) with 3/16-20 bar; it replaced a 21" (?) bow saw that I just loved (as far as downing trees). 310 gets a little heavy when limbing, which means I needa limbing saw. I bought the 310 to do it all. A290 seems to be a good size, and 18 is plenty IMO; weight of tool is gettin to be a bigger factor on my achin back.
What is a skip chain ?
Roscoe Picco Chain said:burr said:I own a 310 (or 031) with 3/16-20 bar; it replaced a 21" (?) bow saw that I just loved (as far as downing trees). 310 gets a little heavy when limbing, which means I needa limbing saw. I bought the 310 to do it all. A290 seems to be a good size, and 18 is plenty IMO; weight of tool is gettin to be a bigger factor on my achin back.
1) a 310 is not an 031, no relation between those two.
2) a 310 is just a big-bore 290, so the weight is the same.
