I had my stove installed last year and the installer did a lousy job. I wanted a block off plate and he claimed it was not necessary since it was to be insulated and sealed at the top. Well a year later I find that he did not even seal the top and my chimney cap got clogged (see image). I can only imagine how much heat is being lost and how the top of the chimney is too cold and creating creosote. Well I got really pissed and he is saying he will come out and fix the cap. I am planning on having him install one like Brother Bart recommends (see below the top is hinged and can be easily opened for cleaning). But reading more I see how many people recommend having the pipe insulated.
Since the pipe is already installed could I just have the top several feet insulated when the cap is being installed? I really do not like the idea of pouring in a liquid to permantley alter the chimney. My chimney is terra cota lined. It is probably close to 30 feet tall. Should I go to the hassle of trying to have the whole pipe removed and insulated?
I figure next summer I will try to remove the insert and make a block off plate at the bottom.
if you click on the link below you will see what I am thinking adding, atleat a few feet.
http://www.chimneylinerdepot.com/store/938/category/Insulation-Blanket.html
