Avalon astoria pellet stove parts ?
coobie
110
southern michigan
Anyone know of a good on line website to buy parts(stove gaskets) for my avalon astoria pellet stove?Thanks,coobie
Coobie, which gasket(s) are you looking for?
If it's the round combustion blower one, just measure the OD of it, plus # of bolt holes, and call Eric at Kinsman stoves (330-448-0300). Those gaskets are all about the same on 90% of the stoves out there, and I think there are only 2 basic sizes.
Eric will match them up for you...good prices and shipping for forum members.
Otherwise, you're stuck with Travis Ind. dealer....they are the only ones that have "factory" parts.
Hello Coobie
Avalon only supplies their stove parts to the stove dealers authorized to carry their stoves.
So in my case, I buy a generic part if there is little difference in quality because the price is usually cheaper!
Example
When I did the yearly cleaning, once I learned that the combustion blower uses a standard 7 inch round gasket, a generic gasket is $9 opposed to the dealer part of $20.
https://www.hearth.com/econtent/index.php/forums/viewthread/60251/
So look for a good part and also know that the wattage of the ignitor elemets was changed for newer stoves.
The old 250 watt Travis Ignitors were changed for large steel stoves to newer lower 200 watt ignitors the end of September 2009
Here is a good web site for Avalon Astoria Ignitors.
http://rockymountainstove.com/avalonlargepelletstoveignitor.aspx
Here is an Avalon Convection Blower but may not be OEM
http://www.spaplaceinc.com/proddetail.php?prod=TRP98900755
Hope this helps
Yes sir,the round convection blower gasket.I just bought 2 at my Avalon dealer today $40 bucks and he is about 50 miles from my house.I fully believe in supporting my dealer also but was looking at buying 1 or 2 extra gaskets off the net to have around.Thanks,coobie.
Don2222 said:
Hello Coobie
Example
So look for a good part and also know that the wattage of the igniter elemets was changed for newer stoves.
The old 250 watt Travis Igniters were changed for large steel stoves to newer lower 200 watt igniters the end of september 2009
Hope this helps
Great write up on the blower and fan.I see that my stove only has 1 yellow oil plug on top.How did you remove the fan?Any detailed pics?Thanks,coobie
Thanks to all who responded.I did find BOTH yellow plugs for the oil(old eyes).I going to give stove a good cleaning later today.coobie
Hello
FYI - More info on Travis Policy for Avalon Pellet Stove Parts.
From
http://www.hearthtools.com/parts/900_ps_1990_97.htm
Travis Ind. (the manufacture of Lopi, Avalon and FPX) policy is their DEALERS can NOT sell parts ONLINE
to customers out of their service area. If Travis catches a dealer selling parts on-line they will threaten them with taking their dealership away of all Travis brands they sell. THIS HAPPENED TO US.
If you dont have a local dealer that sells parts then you are out of luck.
Feel free to send them and email and let them know this is B.S
Hello Coobie
Yearly Cleaning Tips for your Avalon Astoria. See these threads with Pics.
The Convection Fan (Blower) can be removed by loosening the back 2 screws and removing the front 2 screws closest to the side door.
Then the Convection Blower can slide out with no gasket involved.
Wood Pellet Stove Yearly Cleaning - Convection Blower
https://www.hearth.com/econtent/index.php/forums/viewthread/60351/
Wood Pellet Stove Yearly Cleaning - Exhaust Blower
Hope this helps.
Hello
Here is a great web site for Avalon Parts.
They are generic parts but made for pellet stoves and also show the Avalon Part Number.
http://www.stove-parts-unlimited.com/Travis_Industries_Pellet_Stove_Parts_s/55.htm
Example:
IMACMAN is correct. There are basically 2 sizes for Combustion Blowers - Small 6" or Large 7"
So for the Avalon Astoria Large Size Stove, the Combustion Blower is the Large blower
http://www.stove-parts-unlimited.com/Combustion_Motor_No_Housing_Large_p/10-1111.htm
To verify this will fit see the Travis Part # in the above link = Travis #93005535
This 7" Combustion Blower will fit:
* Yankee FS & Insert
* Avalon Newport FS & Insert
You can also measure the gasket on your Avalon combustion blower as a final check.
Here is the 7" Gasket for $12 but if you shop around you can get it for as low as $9
http://www.stove-parts-unlimited.com/Whitfield_Exhaust_Motor_Gasket_Large_p/814005016.htm
Avalon Astoria Auger Motor
http://www.stove-parts-unlimited.com/Merkle_Korff_1_RPM_Auger_Motor_p/12-1010.htm
Avalon Astoria Convection Blower
http://rockymountainstove.com/avalonastoriaconvectionfan.aspx
Thanks for the pics and write up.I cleaned & vacumed the exhaust blower motor & brushed out my stove pipe today and it looked pretty good after 2 tons of uncle jeds pellets.I will clean the combustion motor after 1 more ton of pellets.Thanks again for everyones help.coobie
if all you're looking for is gaskets, most auto parts stores sell the material in sheets, can get a sheet and cut out what you need.
Hello
Interesting List of Replacement Parts that may be needed.
TSM # 1817
SUGGESTED REPLACEMENT PARTS FOR PELLET BURNING UNITS
250-00526 Auger Motor
250-00538 Blower- Large Exhaust
250-00527 Blower- Small Exhaust
250-00588 Blower- Large Convection
250-00532 Blower- Small Convection
250-00011 Control Board
250-00012 Control Board Plug
99300164 Draft Flow Tube
93-0695 Fuse – 5 amp (pack of 5)
93005019 Fuse – 6 amp (pack of 5)
250-00362 Gasket – exhaust cleanout (Astoria only)
250-00228 Gasket – exhaust cleanout (all units except Astoria)
100-03231 Gasket – Large exhaust blower motor, 7†diameter
99300135 Gasket – Small exhaust blower motor, 5 ¾†diameter
250-00357 Gasket – Large exhaust blower body
250-00358 Gasket – Small exhaust blower body
99900431 Gasket – door (7/8 X 85â€)
99900398 Gasket – glass (5/8 X 137â€)
250-00313 Snap disk – ceramic, NO, 2-prong, 120°
250-00314 Snap disk – NC, 2-prong, 200°
This is what my dealer told me too. He said he was more than happy to sell me a $40 gasket, but said you can get the same thing from a $10 gasket kit at NAPA.. :p
Funny, my Avalon Astoria Bay convection blower never had any such square gasket that the pic above shows. It just had rubber-like mounts on all four corners and just rested against the opening in the stove. I never liked that because sometimes it created a vibration noise.. When they replaced the fan (thinking it was overheating, which it wasn't), I put a machine screw through it and attached it tighter. The hole was already there on the fan, and the self tapping screw did the rest. The air flow was (non-scientifically) about 25% stronger afterwards..
