and the wind takes the chimney!
dulcierae
20
Big Timber, MT
Alright guys, I posted earlier about the winds getting pretty out of control here. Today was supposed to be the last bad day but the wind had to leave it's mark before leaving. I believe we have a chimney that is lined in...clay? or something the like. it had been kind of cracked on the top... the clay sticks out above the brick maybe a half a foot to a foot. Well, the winds really whooped today and i went outside and discovered that a whole side of the clay inside is GONE! So my question is... what am I going to do? What is the fix for this problem and about how much will it cost. If there are a few ways to fix it... any advice on the best way. Will it be ok to continue to burn even with half of the top of the chimney gone??
thanks!
You mean that there was a clay tile poking above the brick, right? And that 1/2 of that tile is gone, right? If that is the case, you should be able to hire a mason to remove that single tile and install another. Not sure what cost would be, but I'm sure you won't get away with less than a couple hundred. You should find out where the half tile went - i.e. if it when down your flue, and what that means for your flue setup. Hopefully it's sitting at your cleanout. I'd get on the roof and look at the rest of the top tile. The rest might be loose and worth knocking out before it falls in the flue. Let us know what you find. If you locate the missing tile and it did no damage, I don't see why you can't continue burning until you get if fixed (unless it violates code by being too short relative to roof, etc.). Cheers!
NH, I don't think that this is a tile. It lines the whole chimney all the way down I think and It's all one piece. One side of it cracked and fell off. Someone said something to me about getting a triple wall insert. I have no idea. This is our first stove so I'm not sure of all the lingo or the pieces and parts. Bad news for me. I'm kind of taking a crash course!
Hmmm...okay - I'm not familiar with a solid clay liner, I've only seen tiles. Someone else will be able to help - good luck! Cheers!
It's not a single piece all the way down. What NH_Wood means by "tile" is a rectangular section of clay liner. It's usually a couple feet long and each is mortared to the one below. A mason (or even a good chimney sweep) can easily replace it, if it's only the top one. Not so easily if there is more than one or two that are cracked.
Oh sorry guys, silly me :) I'm learning things everyday... guess that's my piece of info for today! I'll look into a mason or find someone to talk to. but it should be ok to continue to use the woodstove while looking for someone to fix it, shouldn't it? especially if it's just the top piece. thanks for the help guys
Without actually seeing this myself, I would expect it's fine to use unless the broken piece(s) are somehow down inside and blocking the air flow up the chimney. If there is a way you can check for this, it would be good. If nothing is blocking the flow, I would go ahead and burn. First time, though, I'd build a small fire to test the draft and that way, if something is haywire, you won't have a big pile of wood starting to burn but only a very small one. Just use common sense. Good luck.
alright then.... we'll just check it out in the morning then. By the time I noticed it was getting dark. I couldn't believe it happened in the first place. you guys are tons of help! I love this forum, everyone is so helpful!
