I have an eko 40 I am setting up to heat a 500 gal tank (primary loop). I have a two loops off the tank each with separate. 007 taco circ. pump supplying an air exchanger on one and a flate plate water heat exchanger on the other. I am using a zone valve control relay (taco zvc 404) for the thermostat input and zone valve control output.
My question is this: what type of switch would i need to control the 115v pumps with 24v input???
Thanks
RCA
Thanks
RCA
