I need help with 13NC install
bsa0021
406
Ohio
I am installing the 13 NC in place of a VC Dutchwest. The flue in the 13 is located in the center of the stove as opposed to the VC which has the flue at the back of the stove. Therefore, the 13 sits closer to the wall and I will have to get the optional side panels but I forgot about the distance between the flue pipe and the window sill which is 21" to the flue pipe instead of the required 24.5". However the sill in question is 3" below the stove(See first picture). The measurement directly across from the flue exceeds the 24.5". Am I ok?
The other thing is I'm not crazy about how the 13 will look tucked so far back to the wall as compared to the VC. Is there anyway to get the flue pipe extended out in the room further? Obviously, I can't cut another hole in the roof and I don't want an unsafe install (see 2nd pic).
Note: I have 6' of double wall pipe running above the roof.
Thanks!
I don't have the specs in front of me but I am getting ready to install the same stove. The specs permit a certain amount of horizontal run for the pipe. You should be able to solve your problem pretty easily. I would be reluctant to gamble with clearances.
Also keep in mind that this stove requires more thermal resistance for its hearthpad than most stoves. Again, check the specs, but I think it is an R-value of 2.
Good on hearth pad....ceramic tile on cement.
Add a bit more length to the diagonal portion (between the 45's) of the flue and shorten the length attached to the stove to increase the offset from the wall.
what he said. that should push you out a couple of inches.
