Oil or Pellets this weekend? I don't want the pipes to freeze!!
BARTSFAM
96
Central MA
So....when I go to Weatherbug.com, it says that central Mass. could get down to -50 F this weekend with the wind chill.
I was thinking of shutting down the pellet stove and using oil heat for the weekend so the heating pipes don't freeze. I have heard of hot water heating pipes freezing from lack of use in the winter. I never use the oil, except for hot water.
If I leave the pellet stove on, the heat may never come on. I don't know what to do, as I hate to use oil, only as a last resort.
Any opinions or experience with this scenario???
You could use both. Nothing to prevent that.
I manually fire so I can tell the pellet stove to use a setting that doesn't quite handle the heating load and have the boiler handle the rest.
There is also a device you can buy that will run hot water through your hot water base board system so it doesn't freeze.
See here: https://www.hearth.com/econtent/index.php/forums/viewthread/61998/
When it gets down well below zero I will kick the zones on for a bit a couple of times a day to make sure they don't freeze.
When the temp gets down close to 0* I have to open the faucets to let the water trickle. If I don't, well, good by pipes.
I'm afraid the pellet stove will be down for a couple of days until the "Big Freeze" passes by. Good time to clean it out.
House will be heated exclusively with oil much as I hate to do so.
In the 34 years we have lived here I can't recall temps getting down to 0* much less lower. (Danbury, CT area north of I-84).
Going totally pellets, I want to see what this baby can do ;-)
Though I do have a steam system, not water pipes for heating.
Well we've been pretty cool lately and I only have the pellet stove. We have an unheated basement that isn't air tight and I do leave the water dripping to keep the pipes from freezing.
I have a programmable thermostat on the oil heat. Especially in this COLD weather I like to heat up the corners and outer walls twice a day with the oil fired hot water heat.
the people that built my house put the water pipes that go into the kitchen on the outside wall and when I used the furance ( house @ 68) the pipes would freeze when the temps got low. Now with the pellet stove ( house @ 73) and a warmer house all I need to do is open the cabnets and all it well. Now watch I just cursed myself.
I have a old gas hot air deal.I hooked up a simple battery powered thermostat down in the basement and set it at anywhere from 45-50 and it kicks on and keeps the basement warm enough. For good measure I cut a hole in a duct close to most of my pipes and put in a damper this heats up the basement even faster.
I'm going to attempt a pellet-only run at this weekend. The house was cold (56*F) all day while we were gone. I have been home with the stove running for 2 Hours and the first floor is 74/72*F (stove room/opposite corner), and 2nd floor is 67*F and still rising. OAT is +9*F and dropping. Probably won't be shutting her down at night like I have been though, at least until next week.
I'm putting my trust in the Vermonts because I think they can handle it. I know the Okies will, so I will switch over if I have to. My boiler will still run for my domestic tank, so I'm not too worried about it.
To the OP- While the wind will play a part in your heating ability, remember that inanimate objects don;t feel wind chill. Even an efficient house is harder to heat when its windy, but -50*F is unrealistic. Not to down-play the 0* to -10*F that we will all probably experience, but it won;t be bad. By all means, be prepared, but realistically its not going to be so uncommonly, unseasonably or unreasonably cold that we won't be able to handle it.
-15 here for tonight
my pellet stove heats my pipes so I am ok
Let the P68 run on Room Temp mode with the igniter in manual. Put the wall thermostat in override and set the stove to 4.5 (72.5*F) Feed trim to #2, dist. blower on high. And just let her run. All oil tstats were set at 52*F just in case.
The OAT low last night was 0*F and the house stayed nice and warm. Stove room/Living Room/Upstairs was 73/71/68 when I woke up this morning. A hopper FULL of Vermont pellets (72 lbs; 8lbs left in bag) with all settings being constant lasted for 29 hours. Usually I roll back the stove at night to 65*F-ish, but didn't want the upstairs to cool off to the point of the oil boiler kicking on, so I just let her run hard.
I am very impressed and very warm!
Tonight we are looking at a low of -18 with a little more wind, so that will be the real test! We kept the house warm all day so it should be a good jumping-off point!
