Burning mulch
sapratt
397
Northwestern, Oh
If you have dry mulch would it burn good. Or would it burn to fast and hot? I found an endless supply of mulch for free and I was wondering
if I dry that stuff wood that make good fuel for the wood stove?
Loading would be the hard part, and lots of ash.
Excellent fire starter material, but to burn it cleanly you'd have to add a little bit to the fire every three minutes. There is a reason pellet stoves have auger's feeding them. :)
Most mulch has plenty of bark - plenty of ash. Add in the part that you could probably only add a little bit at a time or it will just smolder and that = no way Jose...
If you are talking about wood chips, you can dry them out in the summer to utilize for starting your fire. If it is mulch, I would not burn it at all. The mulch places do not care if they have any pressure treated, painted, or other wood with chemicals on it. It all gets loaded in the hopper and mulched. You also are dealing with added coloring if the mulch is not natural. Mulch also has dirt in it. For S&G's take a handful and light it on fire in a safe place. Smell it.....that will make your mind up. Mulch on fire stinks..not that you are having an open burn, but re-loading will cause some smoke.
+1 for SmokingJay....lots of ash and a very HOT burn. Loading.....well if condition's were right and you did not have to be concerned with the points mentioned above, you would have to load your stove every 1hr or 2.
Take a pass . . . mulch is not firewood . . . I suspect you would find that it would tend to smolder a lot -- not because of any excess moisture (which is possible) but due to the nature of the beast.
If you could dry it well, I think you'd need a fairly specialized burner because when loaded into a stove you would not get good air contact throughout the fuel. It's like burning wood- the air spaces between splits allow flame/combustion to develop and feed it with air. In a pile of stuff you don't have that.
The system may have to operate like a pellet stove where air is forced through a bed that is constantly replenished (you're talking engineering), though some wood boilers claim to handle some of this material mixed in a regular fuel load. The Biomass line claims to handle material like that well. A boiler like that is in my 5 year plan, and I would have access to woodchips- but drying them in bulk would be the engineering issue.
I have also thought about building a passive gasification firebox for my kiln that would burn woodchips, but I do fear dirt and sand that could cause issues for my pottery. It would not be that hard to do with some serious preheating, though it would be a lot of shoveling a little at a time.
Sounds like a smoky PITA
and many places that "make " mulch not only don't care about what kind of wood it is but they dye it and lace it with chemicals to keep the ants, termites and yellow jackets out.
I'd avoid it in your wood stove - mulch and wood chips need specially designed burners, as described above, or they will simply smoulder. You would be thinking about forced air for a start.
Not worth the bother.
Here are someone's results of making a furnace for burning wood chip - they gave up on it after a while as they had too many problems.
http://www.sredmond.com/vthr_index.htm
