lol that's a little to bigsoupy1957 said:First off, before name brands fly around, consider the size and amount of wood you believe you will be actually splitting. Some folks only use their log splitter for re-splitting oversize splits. Some folks use them for splitting all the wood they have. If you are only going to be doing some small scale amounts of splitting, don't "overkill" your spending. You can find some really decent 5-ton splitters (brand name aside) at Lowe's and Home Depot, that work fine for smaller jobs (rounds under 10 inches or so).
If, on the other hand, you are thinking of doing a full-scale splitting operation, you could always go THIS route............
thanks northern tool has some good prices . I am not sure how good they are, does any one own a timber wolf??Naandme said:Check out Northern Tool they got some nice spliters on sale now
dr.drew said:thanks northern tool has some good prices . I am not sure how good they are, does any one own a timber wolf??Naandme said:Check out Northern Tool they got some nice spliters on sale now
Thanks Dennis and happy new year my friend !! ps what kind of splitter do you haveBackwoods Savage said:I would not get hung up on the size....within reason. I know the trend is to get big ton splitters but those 30 ton and up splitter are a bit overkill. Our 20 ton works just fine. On the really knotty stuff or stringly elm, there is a two-stage pump so the speed will slow to give more power. It does not stay in the low speed very long though!
Cycle time is another that folks like to throw around; how much faster the bigger splitters are. Yes, they are faster but once you start splitting wood you'll probably find that you very rarely have to use the entire cycle! For example, I hardly ever raise the ram (or wedge) all the way up. There is no need to and that would be wasted time and wear on the machine. On a lot of firewood you don't even take the ram all the way down as the wood splits with the wedge just part way through, so cycle time is a non-issue....to most folks.
So my recommendation is to get somewhere around the 20-22 ton. You will save many dollars and it should do everything you need done. You'll be laughing at the ease of splitting wood once you have one.
thanks I will look into the splitfiresmokinjay said:dr.drew said:thanks northern tool has some good prices . I am not sure how good they are, does any one own a timber wolf??Naandme said:Check out Northern Tool they got some nice spliters on sale now
Timber wolf and the spitfire are top of the line splitters.
I have seen huskee at tractor supply, I was not sure how reliable they were.Backwoods Savage said:Ours is an MTD with a 5 hp Briggs & Stratton engine. It is still basically like the Huskee splitters with just a few differences. I think I could be happy with most of today's splitters as long as they will split veritcally. I ain't picking up every block of wood to split it! I do my splitting sitting down.
Actually, in many cases the higher tonnage splitters have slower cycle times unless you get into some of the higher priced brands. To keep cost down, they often put too small a motor and pump on them. Size really does matter when it comes to cycle time.Backwoods Savage said:Cycle time is another that folks like to throw around; how much faster the bigger splitters are. Yes, they are faster...
LLigetfa said:Actually, in many cases the higher tonnage splitters have slower cycle times unless you get into some of the higher priced brands. To keep cost down, they often put too small a motor and pump on them. Size really does matter when it comes to cycle time.Backwoods Savage said:Cycle time is another that folks like to throw around; how much faster the bigger splitters are. Yes, they are faster...
wow the splitfire is very impressivedr.drew said:thanks I will look into the splitfiresmokinjay said:dr.drew said:thanks northern tool has some good prices . I am not sure how good they are, does any one own a timber wolf??Naandme said:Check out Northern Tool they got some nice spliters on sale now
dr.drew said:wow the splitfire is very impressivedr.drew said:thanks I will look into the splitfiresmokinjay said:dr.drew said:thanks northern tool has some good prices . I am not sure how good they are, does any one own a timber wolf??Naandme said:Check out Northern Tool they got some nice spliters on sale now
dr.drew said:I just watched a video of a log splitter WOW check it out www.supersplit.com/video1.htm
Jay do you mean SPLITFIRE, I could not find a website for spitfiesmokinjay said:dr.drew said:I just watched a video of a log splitter WOW check it out www.supersplit.com/video1.htm
its kinda like the spitfire.
