Two Decades with a VC WinterWarm
SPhill
The house was designed and built around a central wood burning stove. The hearth and flue were designed for the WinterWarm insert. The 4 x 9 foot block chimney is surfaced with fieldstone and exposed to the first and second floors up to the cathedral ceiling to serve as a heat sink. The cold air return shaft runs down the chimney adjacent to the flue so as to heat return air going back to the heat pump air handler in the basement.
With temps below 20F, the WinterWarm augments the heat pump nicely, preventing 2nd stage electric activation and limiting heat pump cycles to just enough to circulate warm air for even heating. In an electric outage, the WinterWarm will heat the entire house (though not very evenly) and keep the water pipes from freezing. We also made provisions for a coal stove in the basement with a third flu that is capped off -- just never saw the need to use it.
All the stone came right off the property. The oak mantle is perfectly straight (camera gives a fisheye effect). The unit sits on a 12" thick concrete floor and no structural wood framing is closer than 4 feet to anything that gets hot.
I change the catalytic combustor about every 6 years. This winter I overhauled the unit and installed all new gaskets. The WinterWarm has been an efficient, reliable heater for 21 years.
Looks and sounds nice. Twenty-one years is a good shakedown cruise. I would say it is good to go for the long haul.
Looks good for 21 years I enjoy my sand enamel as well. Do not understand where the negative feedback comes from for these units. I would bet they are not properly installed. Fireplace units the same as woodstoves must be properly shut off from the chimney or else all your heat from the firebox escapes straight up the chimney before it ever gets a peek at your living room. See that your wife likes those blasted candles as well.
Welcome samdog. That a beautiful setup. Nice to hear that the stove continues to provide good service.
Sounds like a well thought out and planned set up! Just what you need to be happy with a wood burning stove/insert. Probably what's lacking when people complain about most stoves. It is a beatiful set up! Welcome aboard Samdog.
Thanks, appreciate the comments. Just found this site. Great info here!
vc said:
Looks good for 21 years I enjoy my sand enamel as well.....See that your wife likes those blasted candles as well.
Candles, candles, oh yeah. Try to make the stove nice and safe and she's got open flames all around the place :gulp: Wax drips on the mantle.....wax drips on the stone....and I go around at night with the lights off, making sure I put out every one. But man, can she cook! %-P
Do not see the digital thermometer. It is a must to know what temperature your cat is burning.
It's out of sight.
Glad to see an insert that works like it's supposed to!!! I think the single reason that people become unhappy with their Winter Warms, believe it or not, is that many are run with no thermometer! I don't know if dealers don't point it out that you need one' or if customers figure they can't spend the extra $ or what. Another reason I've found is those who live near the ocean can have terrible rust ing problems. Apparantly some installations just don't dry out in behind there or something 'cause I've seen som that are just ROTTED! Tragic, really. I'm quitr sure as well that people sometimes push them too hard. In a milder climate like PA they might very well do a great amonut of work, but way up north we just can't expect as much from them. THey are such beautiful units, I'm really glad to hear a success story like yours. Happy Heating!!!!!!!!!!!!!!!!!!!!
im impressed. proof that purchasing a great stove and sticking to it works. very nice. pete
Very nice looking hearth and insert! Glad to see it has served you faithfully for so long! Welcome to the forum Sam.
Ray
