north of 60 said:Pictures tell me over fire or chimney fire has existed.
SmokeyCity said:not sure how to measure humidity accumulation
i burn hot hot hot most of the time so as not to put creosote up the tube
is it correct to put a key damper on a secondary burn stove ?
i googled solar powered wood dryers a whyle back and got some great info. basicaly a shed with a clear roof and front that let the sun in and a fan that would circulate air through the chamber once it hit a certain temprature. if i remember correctly the wood got hot and stayed that way well into the night. it was a speed drying method i thought was neat. im giving more space between rows and using the wind after what i read. but as we all know theyres more than one way to dry wood. keep safe and i like the house picture, simply charming to say the least. pete
iceman said:Maybe that's an old pic of the stove? Reason i say that .... those pipes need to be changed ASAP... the white/grey ones are worn from getting to hot...
Split the wood, stack it and bring it inside in the fall ... and bring enough for the nights burn plus a week or 2.. that way what's not dry will be....
Get a stove top thermometer, cause I have a feeling its getting. HOT...
The way those pipes look with dry wood you should have no prob shutting stall the way down and getting nuclear... and you could then Be able to get rid of the heat reclaimer....
I am sure someone will chime in with more info
iceman said:SmokeyCity said:not sure how to measure humidity accumulation
Does hot hot mean you leave it wide open or half open for more than say 20 minutes?
Your epa stove actually gets warmer with less air assuming you have dry wood.... brotherbart can explain. Best about that stove .. but get rid of the reclaimer, put some new pipe on there ... and those rounds def need to be split ... and get the chimney cleaned ...you will see a huge diff ... that sucker will surprise you
gil said:You don't want to burn your house down do you?
SmokeyCity said:gil said:You don't want to burn your house down do you?
ITs triple brick and everything is masonry and the cielings are fire proof plaster rock wire reinforced
I dont wanna try tho
The pipe isn't discolored, it's galvanized. When you start changing pipes, you should get some 22 gauge pipe from your local hearth shop, it will last much longer.iceman said:SmokeyCity said:gil said:You don't want to burn your house down do you?
My fear is you ruining the stove.
Leaving the door cracked until you get good secondaries is letting your heat up the chimney.. that explains the color of the pipe ... once your fire is down to coals... open air and reload... close the stove door leave air all the way open for about 20 minutes... the close it half way then 25% then all the way down total time maybe half an hour? You want to see secondaries but not a roaring fire with them.. the stove will work itself up temp...(with your draft could be 7-800)
You aren't burning the way most would recommend, and that's why.it seems like the reclaimer works.so. well... the pipes are so hot that thing Prolly feels like a forced hot air furnace!
Thumbs up to you for coming here... most of us were all I. A similar place when we first came here too!
north of 60 said:10"by10" rectangle chimney? Not making sense to me.
Cheers
wood-fan-atic said:I've pondered the kiln idea myself,several x. Usually in the fall when I discover my oak isnt quite as dry as I had hoped. Then I come to my senses and decide to stack more/better/earlier for next year. Also, why not try splitting those rounds down to 5"-6". You'll be amazed how much faster they dry,and how much better your stove will run.....just my .02 cents.
SmokeyCity said:north of 60 said:10"by10" rectangle chimney? Not making sense to me.
Cheers
The interior tube of the chimney is 10 by 10
Here is a pic of the cutaway view looking up.
all my chimneys are like this and are almost 60 ft. The draft is huge.
I had to open this one up but never ended up using it
north of 60 said:SmokeyCity said:north of 60 said:10"by10" rectangle chimney? Not making sense to me.
Cheers
That looks square to me.
