We started one of those "easy" remodel jobs on our fireplace and have run into trouble and are looking for some advice. Our plan was to tear the outer brick off the fireplace and hearth and replace it with a more modern rock front. When we took off the brick, we discovered the fireplace doesn't look very safe. There is a metal angle iron bar at the top of the fireplace. It is just sitting on the bricks at each end. Then the 12 inches above that piece of iron there are bricks standing vertically that have mortar in between. There is nothing behind those bricks. They are not attached to the iron bar. Now above those vertical bricks is another iron bar that seems to be connected to the chimney and starts the firebrick. There is firebrick on all the sides of the firebox except where that row of vertical bricks are. I'm attaching a picture that I hope you can see.
Can you tell us how to rebuild this fireplace to make it safe before putting the new rock on it? is this something that my husband and I can do or do we need to hire a professional? Please advise.
Many thanks for any advice you can offer.
Jack and Lynn
Jack and Lynn
