Hello
This does show pellet stoves burn more cleanly!
See more info here!!
http://www.facebook.com/topic.php?uid=136130219752540&topic=232
You can use pellet stoves during a burn ban. Pellet stoves burn clean enough smoke that you can burn them during a stage one burn ban in many places. Burn bans usually happen when air stagnation is high which happens a lot during the cold months. People using wood burning stoves with another source of heat in their home have to turn off the fireplace, however pellet stoves are fine to use.
What is a burn ban?
http://www.pscleanair.org/airq/burnban/
Stage 1. During a Stage 1 burn ban:
No burning is allowed in fireplaces and uncertified wood stoves, unless it is your only adequate source of heat. This includes the use of manufactured logs such as Duraflame or Javalogs.
You can use pellet stoves, EPA-certified wood stoves and natural gas or propane fireplaces.
* No visible smoke is allowed from any solid fuel burning devices, beyond a 20 minute start-up period.
Stage 2. During a Stage 2 burn ban:
No burning is allowed in any fireplace, pellet stove or wood stove (certified or not), unless it is your only adequate source of heat.
You can use natural gas or propane fireplaces.
* No visible smoke is allowed from any solid fuel burning device at any time.
What is a burn ban?
