So my Englander 30 is finally up and running thanks to this forum! My wood for next year is seasoning in my back yard so I'll have to buy some firewood for this upcoming season.
I have a 1600 square foot two-story colonial that was built in 1900. Suprisingly, its not that drafty at all..probably due to the new doors and windows. The attic has r-38 insulation. I'm finding many of the rooms don't have insulation on the exterior walls, maybe 20% actually do. The house holds its heat fairly well. At 0 degree temps it will lose about 1.5-2 degrees per hour if left unheated. I live in central Massachusetts and temps are usually in the low teens at night and 30ish during the day.
Okay, now that all the science is out of the way....how much do you expect me to go through? I plan to heat 75+ percent with wood and supplement the rest with the existing steam system. The existing system will probably just be set at 55 or so. I aim to keep the house temp at 70 degrees or a tad warmer (we'll have a newborn).
Thanks!
Thanks!
