Friends! It is done, waiting for a w.e.t.t. inspection(Canada). It was a job, putting in a new chimney and the learning curve. It is an ICC Excel chimney system-the thought I have is that the through ceiling coupler could have been a little wider (for my peace of mind) although it is all certified. Also tricky to keep everything plumb to maintain proper clearances. Plus I had to go through a rafter and floor joist which meant extra bracing. Also a 4' length turns out to be 46-1/2 when coupled; had to add 1' to maintain height.
The hearth was the easier part but anyone who has done it knows tile glue and grout is messy! I had a $60 tile saw, and that worked well. A cold air intake was installed that draws from the basement, on this stove a 4" hole (with rodent screen) needs to be located under the pedestal.
So waiting for the inspector before firing. The latest issue I have is with fire insurance; it seems my company does not like wood heat; they even sent me a letter previously encouraging me to switch away from a wood furnace! I understand the unknown is the ability of the stove operator!
Anyways I am now committed, :lol: with the wood stove community. Found 2 new sources of firewood, "Firemasters" make packs of campfire wood and ship all over; even to Alaska! they said; so all the culls and improper splits are discarded out back :cheese: which I can get for $10 a pick-up load, this is dry seasoned spruce, lodgepole pine-do not have to split or start my saw, just transport and stack.
