stove for uninsulated cottage in mid-coastal Maine
RAPhomme
41
mid-coastal ME
Hello, first post here.
I'm looking for advice for a stove for an uninsulated but well-built house/cottage on Mount Desert Island in Maine. The cottage is around 1200 square feet, on two levels, with a basement. The basement is walk-in height (8 ft?), dirt and gravel floored, and has a huge cement block in the middle (maybe 6x5) running from floor to ceiling, whose original use I've never figured out, and which takes up a lot of space. The main floor has living room, kitchen, bedroom, and bath. Upstairs, above the kitchen and bedroom, are two small bedrooms and a bath. The living room has a high, sloped, "cathedral" ceiling. The layout on the main level is quite open; the stairway is also open with no door at either end.
The place was built in 1970 on the foundations of the original farmhouse. It was designed by my father (an architect) for my grandparents as a summer home. That's why there's no insulation (though it seems, to my untrained senses, to be quite "tight" for what it is). As far as I know, it has only ever been used from around June-September/Oct.
There is an old Franklin #2 stove in the living room. The stove pipe runs straight up, for probably 20-25 feet, through the ceiling to the chimney pipe. Although there is good passive solar energy from southerly windows, the stove is the only active source of heat. There's an electric hot water heater in the basement.
Currently it is rented during the summer. For the past few years, I've gone with my kids for a few weeks at the end of the season. But every time I go, I love the house and the place more and more. So the thought has been entering my mind that at some point in the next stretch of years (3, 5, 10?), I might want to try living there longer. I imagine this could range from simply spending the whole summer, to stretching out into Feb/March/April or Oct/Nov, to at the extreme spending most of the year. So in that light, here are some of my concerns:
1. The old Franklin is what I've seen well-described here as a "smoke dragon." I really noticed it this year: every time we lit a fire, the interior of the house smoked up, and the stove wasn't even really heating the place well, unless really cranked up and roaring away. So the Franklin is inadequate right now. It's also dangerous--sparks do fly out of the front doors. It makes me nervous if renters are inattentive.
2. The main question: how reasonably comfortable for how long in the year do you think I could expect to be with a modern stove? In that part of Maine, the average low temperatures are Feb: 14, March: 22, Oct: 38, Nov: 29. Lowest lows in Feb/March: -10, -15. Does trying to stretch the livable period into the colder months even make sense in an uninsulated place in those conditions?
3. There is a pretty big range of uses to which the stoves would be put. For renters and during the summer, the occasional fire to take off the chill and for viewing pleasure. In the earlier spring or later fall, as suggested above, the demands would be considerably higher. Are there stoves that can accommodate such a wide range of applications? Can bigger stoves make satisfying smaller fires, without being overpowering?
4. I think wood heat is the only option: the stove is central to the character of the place, and I wouldn't want to change that. I grew up in a wood-heated house (stove and furnace): it's something I'd be happy to return to. Given that, it's important to me that the stove be good looking (subjective as that is). And given that if I ever did decide to live there for the colder months it would be necessary for life and comfort, it's important that it be robustly reliable, long-lived, etc.
5. My strong preference is for a stove that could last the night on one burn. If I ever decided to live there, I'd want to be able to live more or less normally, with a regular sleeping and working schedule, etc. Long burn time seems crucial.
6. To give you an idea of my current thinking: from reading around on the forums as much as I could, I like the sounds of the Woodstock stoves, also maybe also the Jotuls. But how big on either of these (or any others)?
7. Does anyone know if the tax credit would apply to a house that's currently mainly used as a rental? Sounds unlikely.
Thanks in advance for any help! The decision is not imminent (though I do find the Woodstock sale tempting)--I'm asking partly because it's all in my mind since we recently returned. And in part for medium-term planning, to begin to figure out if any of these fantasies are even possible.
Welcome to the forums!
It certainly sounds like a fantastic place.
IMO, the first thing I believe you should consider is simple: insulate. If there is litterally NO insulation, it will be near impossible to heat when it's -10 out no matter how big of a stove you install. I think, without insulation, you could stay until October. After that, things can get downright chilly.
A big stove can make a small fire....but you can't make a huge fire in a small stove. I believe it's always better to go big or go home when it comes to a stove (within reason). Getting a1.0 cu. foot stove will run empty a lot faster than a 3.0 cu foot one.
There are lots of stoves with great long burn times. Cat stoves can have small fire for long times. Non-cat stoves can as well (though not quite so long). It depends what you want...budget, etc.
Woodstock and Jotuls are great stoves. Keep an open mind, there are great stove companies out there. Lots of them could meet your needs, look around read and research. There are Harmon, Osburn, Lopi, Englander, Drolet, Blaze King, Vermont Castings, Quadra Fire, Pacific Energy and the list goes on and on!
I think that as long as the housen is in your name, they don't care who lives in it. The fact of the matter is that the government is willing to fork out cash to remove inneficient stoves, no matter who is using them. I don't see it being a problem if it's a rental...then again, I could be wrong.
Andrew
Best BANG for the $$$$$ investment has the Englander 30 N-C as a good possibility, especially if you are contemplating a basement install. But as mentioned above, some insulation should be added as well. welcome to the forum.
Welcome.
For sure, get that old stove out before somebody gets hurt.
+1 on the insulation. Well insulated, 1200 sq ft, a Fireview would be perfect. I suppose you could get a big enough stove and feed it enough wood to stay warm without insulation, if it's not too drafty.
By the way, we like pictures.
Welcome to the forum Norumbega.
Without insulation I'd still bet the Woodstock Fireview would give you enough heat up until about Christmas time. After that the cold will set in and without insulation methinks you would spend some very cold nights. Of course you could also go with the newer Woodstock stove too but you would probably be better served by putting in some insulation; especially on top. Heat rises and that is where you'll lose the most so that is a good starting place.
It sounds like an excellent place and I can relate to your future plans for it. Hopefully you have also considered how you will get the wood that you need. Also, hopefully you will not follow the old time practices in wood burning and that is mainly in the drying of the wood. Gone are the days when you go cut wood in the fall and burn it all winter. You won't do that is today's stoves. Get a minimum of a year ahead on your wood supply and I always suggest 2-3 years ahead. Then you are assured of having good fuel.
With the Fireview stove, we bought one 4 years ago and now use only half the amount of wood we used to so they indeed are great stoves and you can't beat their guarantee. Yes, there are other good stoves out there. Do your homework well as it sounds like you have time on your side. Good luck.
Thanks for those quick responses.
No, there's no insulation, no sheetrock: it's beautiful but bare-boned (the bare bones are part of the beauty): all pine 4x4's and tongue-and-groove pine cladding.
But on the other hand, it's not drafty, at least not that I've noticed on cool summer nights.
I have wondered if there's a type of removable insulation that could be placed into the spaces between studs and joists. I remember a family I knew as a child who would place insulating panels over certain walls and windows in cold weather. At this point, unless I became much more dedicated to this idea, it seems too much (financially, aesthetically, time-wise) to install permanent insulation everywhere. But who knows?
I guess I naturally gravitate to those responses that hold out hope! I am thinking well into the future here, so it would probably make sense in any case to try a few smaller steps before trying to survive -10 degrees with one overtaxed stove. Maybe just getting a new stove in there, since I need that anyway, and seeing how it functions into more challenging conditions will tell me what can or can't work next. One of the reasons for liking the Woodstocks: when you're uncertain as I am as to actual needs, the trial period is very attractive.
Right now, I'm assuming a new stove would go in the old one's place: in the main living room. Basement would be tough to arrange--though I do wonder if that old cement block down there was some kind of furnace?
BSavage: I have thought about wood a bit, mostly because of your and others' advice in other threads. When I was a kid, we'd just go out into the woods, pull out a log that the loggers had left, cut it up, split it, and more or less toss it in the fire. I guess times have changed! I think in this location, I'd have to buy wood. We do that already for the summer, but I'd want to pay much closer attention to quality, drying times, etc. There's a wood-shed my grandfather built, so space enough to store what we'd need.
So maybe March-Oct/Nov is a realistic limit to think about. Not a terrible prospect.
I'm not fixed on any brand, though I admit I do like the guarantee, reputation, and long-burn of the Woodstocks. People have mentioned the Fireview--is that the general size most would assume as correct for this space and conditions?
Sorry, I don't have any pictures on me!
Welcome to the forums. As I read your needs the Woodstock Fireview was the first stove that came to my mind. It will definitely provide overnight burns and will have the reserves to heat the house well if the weather gets really cold. However, this is a cat stove and it really is going to prefer well seasoned wood. If that is not a possibility then I would consider a Maine made Jotul Rangeley or a Pacific Energy Alderlea T5 for a non-cat stove. The Alderlea is a simpler stove with a novel trivet top for easy cooking, mitten drying etc. The Rangeley is a top loading stove that is a bit new to us, but looks to be pretty solidly made.
As to the solid cement block column in the center of the basement, my guess would be that it supported the fireplace and chimney in the original house.
Thanks for that, BeGreen. When you say the Fireview would "have reserves to heat the house if the weather gets really cold," how cold are you thinking? Is this with no insulation in mind? I'm not trying to be definitive this far in advance; just collecting different data-points as to the feasibility.
You know, you're probably right about the cement block--its current use is in supporting the steel I-beam my father put across the whole floor at the insistence of my grandmother, who was especially scared of hurricanes. So if you're right, it's still serving basically the same purpose.
I'll go look around some more, but is there a best thread or place that talks about cat-stoves needing better seasoned wood? Thanks.
In a 1200 sq ft, tight home with a centrally located Fireview I would expect it to heat the home to the point where the greater concern would be freezing pipes. It has a pretty broad range of temperature operation.
Well seasoned wood really makes a difference with any modern wood stove. Even with older stoves, the drier the wood, the more heat you get out of it. But cat stoves are a bit more particular about this. Burning damp wood can shock the catalyst or make it hard to get the stove up to the temperature required to fire off the catalyst. Dennis is a Fireview owner and a strong advocate of dry wood so I will let him follow up on this question.
beGreen brings a very good point to the table: frozen pipes. If it is -10 outside and you have a nice fire going inside, you would still need to ensure that the pipes are heated (especially since I presume they are in those typical "hard to heat" spaces".
As for insulation you could remove, why remove it? Where would you put it after? You could always look at Roxul: it's a rock wool that is considered to be fire retardant and moisture resistant. My guess is that for $1500-2000 you could do most of the walls and the ceiling. For $800 I did an 8 foot wall (basement) that had a 156 foot perimeter.
Dry wood, as others have mentioned, is key. Boiling off water and clogging a chimney (and a much greater risk of a fire in the chimney) is a bigger headache than drying wood. I know people who still do the "cut it, split it and throw it in" method and they end up having a chimney fire every 2-3 years. They don't listen.
Andrew
I would insulate…you could then use tongue and groove pine instead of sheetrock so it doesn’t lose that cottage feel. There is no way your pipes won’t burst at some point if you’re attempting to use plumbing in the winter with no insulation. Also most of the piping outside of those cottages are not set up for the winter so if you are planning on leaving the water on after the temp drops you might need to look at the plumbing on the outside of the cottage as well. Your main concern here is not the cottage stove but the cottage construction.
That was going to be my next question: about the pipes freezing.
Rex: you're right that there's actually a fairly natural way to lay the insulation in existing recesses between studs/joists and then cover it with pine boards. I can imagine that working pretty well.
In terms of pipes in general---I've looked a bit at heat tape, etc., including versions on thermostats that come on when it gets cold. Is heat tape generally thought to work reasonably well? There aren't many pipes in the place, and most are run centrally; so if something like heat tape could work, that would largely solve the problem.
So there do seem to be two separate questions: if the interior can be heated sufficiently in winter; if the pipes can be protected from freezing. Insulation would help with both. But, just for information purposes, what do you think the limit of cold might be, for both questions, if there was no insulation? How deep into cold could a decent stove get me for the interior? How deep into cold could heat tape or similar get the pipes?
Thanks for all the help.
I don't know the answer to your "How low can you go w/o insulation?" question, but if I were going to try that, I'd want more stove than the Fireview. A thought about movable insulation: rigid foam panels, especially over the windows.
I'd try getting a nicely installed Englander in there. Try it out on the cool (not freezing) nights in the fall. If you are absolutely loving being there you can think about what to do regarding the insulation and plumbing. There's heat tape and etc you can get for the pipes, but I don't know if you would want to leave things plugged in when you won't be there for long stretches.
I live 30 miles from your "camp", I can't imagine trying to live on the Maine coast in an uninsulated house with a wood stove for heat. I can see it as a camp but a home, wow I'd insulate. Pipes will freeze in a heart beat, I suppose you could heat tape them, insulate them and get away with it if you're very thorough.
My buddy has a camp north of Lincoln Maine, we'd go up in the winter, no insulation in a 2 story camp. Pretty tight building, it was at one time the caretakers camp in a sporting lodge. It would take all weekend to get it up to temp using a fairly hokey woodstove. With a modern Jotul I imagine one could heat it better but the walls were always drafty because there was no insulation, you radiate your heat right thru the walls, kind of like sitting next to a large window. Again a good wood stove would allow one to be there at Thanksgiving and be comfortable, Christmas thru March and you'd want to be tough :lol: . MDI is a great place I can understand why you'd want to be there more
On pipes freezing it brings to my mind when I was a bit younger. We milked cows in stanchions rather than milking parlors. The milk house was separate from the barn but connected by an enclosed walkway. We had no heat in the milk house but, of course we had to have hot and cold water for washing milkers, buckets, etc. We simply wrapped the water pipes with heat tape and never had a problem with freezing lines. One thing we did though was to drain the water heater when we were done with the hot water so that meant doing it morning and night.
The milk house was a cement block building and because it was closed off from the barn the only heat given was from the compressor running the milk cooler. It got interesting when washing all the milkers etc., but my point is that we got it done and did not have frozen pipes. On our house now when I put the water line in (we drove our own well) I put heat tape and wrapped that with more insulation. That was done in 1979 and we have never had frozen pipes. However, when the water comes in the house, all the water lines run inside along the walls. That way we knew as long as we heated with wood we'd have no problem and we have not had a problem except one time when the water froze in one spot. It was a very quick job to get that thawed out and it was under the bathtub where it froze. I don't recall for sure what the temperature was outdoors but think it was somewhere around -20 and the wind was wrong so that it created a super cold spot under that tub.
I'd still stick with my earlier opinion that without insulation you would most likely be okay until Christmas and then again perhaps starting April 1. In between those two dates it would most likely get pretty uncomfortable in the cabin except right by the stove.
On the cat and dry wood. Yes, dry wood is necessary no matter if a cat or non-cat but perhaps more so with the cat. However, that may change slightly now with the new steel cats vs. the old ceramic cats. I'll be installing a steel cat soon in our stove but no matter, we have lots of dry wood. Also, because I don't believe in burning marginal wood I am a poor one to ask about unseasoned wood; I just don't want to burn anything like that no matter what type of stove I have.
Thanks for all those answers--lots of great info.
Sounds as though the consensus is pretty clear: insulate to be there in winter; otherwise, Novemberish into Dec is probably the fall limit, and then April or so in the spring.
Yes, smaller first steps, like trying things out in the fall first, will be necessary to show me how well my wish to be there survives the cold. And will indicate what further steps then need to be taken.
I'm glad to hear that heat tape can work well--even if I'm never there all year round, it's good to know there's a fix for the pipes if needed.
And I'm now dedicated to properly dried wood when the time comes. I haven't thought about living with wood since I was 15; it's amazing to come to grips with some of those same questions my parents must have had when they were my age now.
Dennis' story about milking reminds me of one spring I spend with a Mennonite friend on his family's dairy farm in Kansas--those were some cold mornings in the barn!
Really feel like this has been a quick and thorough education in the possibilities and the problems. Lots of folks who know a lot more than I do. Much appreciated.
Hey, those cold mornings really weren't so bad....except when a cow needed help delivering a calf. That you could usually count on being sometime between midnight and 4:00 am. Glad you got a taste of that life.
I have a friend that has a camp in northern Maine, like yours its uninsulated and he has a wood stove. He only uses the wood stove in late fall on those chilly nights, the rest of the winter he doesnt even go to the camp any more because its too cold even with the wood stove burning. He said hes going to insulate it so he can use it in the winter, that is if he can get to the place with all the snow they get.
Get to insulating and cover in pine.This place was built in 1800,uninsulated i learned.Roof is insulated and cellar walls but exterior walls are not.Horse hair plaster so it's tolerable.New stove this yr,insulation next yr.Only because we have to rip clapboard and vinyl siding off then insulate, plywood and vinyl back on.I just don't have the time quite yet.
In all of this, we have spoken about insulation, plumbing but forgot one thing: TOILETS GET COLD TOO! ;) I have never heard of, or seen, a stove in a bathroom, perhaps this could be a first!
Andrew
The fireview will not work for you in those conditions.I sent mine back and I'm in Eastern Ma.A friend insulated his house from the outside by attaching foam boards to the outside walls of his home in New Hampshire.He now says at times it gets so warm in his house that they have to open a window so they can stay in the house.Your situation calls for at least one of the bigger stoves or else I think you'll be sorry you didn't and we won't hear from you anymore due to being ashame.
@Bub381: this whole question has made me more curious about how they used to heat their houses in these cold spots. I guess "horse hair plaster" is one answer. Mud, brick, stone, and snow might be others. And I guess smaller houses, lots of fires, and higher tolerance for discomfort are part of it too.
You could find all sorts of solutions based on the knowledge of the builder and original owner, availability of materials and budget. Some older homes were built with a lot of common sense to minimize drafts and maximize heat. Other homes were not. I have seen old houses use sawdust for insulation, newspaper sheets for a windbarrier under the sheething, with good plaster jobs and centralized heat sources. Usually one in the kitchen and one in the main living space.
