HollowHill
BrowningBAR said:HollowHill said:BrowningBAR said:I'm interested in your floor plan. I am assuming it is a traditional non-open floor plan? I hope I am wrong. Is there any chance you have a centrally located chimney like a traditional 4 square farmhouse? I don't which is why I have three stoves.
You are right that it is not an open floor plan. Traditional federal layout - large central hall with open staircase to 2nd floor, which also has a large central hall. Rooms radiate off central hall. Interior chimney in front room off central hall, middle back of room, so about 10 feet from the center of the house. Judging how heat rises in this house, I'm not too worried about the second floor. The back kitchen and room across the hall from the stove room may have problems.
I am interested in knowing how the new stove works out for you. I am pretty sure I will buy two at some point. (They will replace the Heritage and the Vigilant).
Will do. I'm a newbie, tho, at woodburning, so your mileage will most likely vary to the better.
