CDW 288CCL Oval adapter
woodchuk
7
Appreciate the community and knowledge available here.
Replacing a 27 year old 288CCL Insert with a newer used model 288CCL. (longer post later)
and need to order an Oval to 8" adapter.
The old Oval to 8" pipe adapter is a bit ratty and would like to replace it while everything is accessible.
It will be coming out of the stove horizontally and into an 8" Tee with Cap for sweep/clean.
ID Measurement of the Stove Oval is 10.5" x 5"
Found these adapters:
http://www.elitedeals.com/cpf-21376.html (but oval is described as "5 3/8 X 9 3/4"
http://www.elitedeals.com/cpf-69195.html (would need a new Tee for this item)
Perhaps Part# 1860-CD is what I'm looking for here?
http://www.woodmanspartsplus.com/258618/products/Vermont-Castings-Oval-to-Round-Boots.html
Anyone have experience with the fit of the oval adapters?
Best way to seal the adapter-stove junction?
Best Regards,
Woody
This is what you are looking for and it's one of the only places I have found it other than ordering it from a VC Dealer. All the other oval to round adaptors not designed specifically for the Dutchwest do not have big enough ovals and can be a pain in the rear to try and make work.
This link is for the oval to round 8"
http://www.sandhillwholesale.com/el....html?osCsid=87944f89c67d439a3cde97b4a5252a57
They also have a shorty adapter. Here is the link to most of their oval to round adaptors.
http://www.sandhillwholesale.com/ad...Csid=87944f89c67d439a3cde97b4a5252a57&x=0&y=0
Thanks Certified106,
I believe the current part is a shorty.
There's a SS flexi from the Tee top to the main.
The bottom of the Tee currently angles toward the stove slightly due to the shorty adapter.
I prefer the length of the offset part which will push the Tee back.
To clarify:
If mounted horizontally, is the new part's offset Left/Right or Up/Down?
thanks,
woody
Perfect, thanks.
Any sealing needed around the junction?
edit: nevermind, plenty of info on that subject
woodywood said:
Perfect, thanks.
No problem, I should have also said welcome to the forums and hop you stick around and show us some pics of that stove when you get it installed. My family and I have owned Dutchwest stoves for years and always found them to perform well and require very little maintenance, Hope you enjoy yours! As far as sealing the stovepipe I have always used some furnace cement around the oval part to ensure it was sealed going into the back of the stove the rest of the stovepipe I never worried about.
