clearance to combustibles
jason elmer
28
west michigan
I will be installing a Biomass 60 soon and was wondering about clearance to combustibles. It is labeled for 18" on the sides and 36" both front and back. As the boiler is rather long this results in a large footprint. The 36" in the front seems reasonable as the doors when open can release a lot of heat but the 36" to the rear seems excessive when it's 18" on the sides.
Has anyone with a Biomass or EKO boiler cheated on the rear clearance? That's on a framed wall not concrete.
Thanks
I think the rear clearance is in part to provide room to clean the boiler.
Don't forget that it also needs 36" top clearance. There was no mention of this in the owners manual, just on the ul tag.
How much is room is needed for clean out in the rear and plumbing. Bottom line I would like to shave it down to 30" or even 28" of clearance. I know you can hang sheet metal behind a stove to decrease combustible clearance requirements.
I have substantially less than 36" behind my EKO. However, my boiler room wall is concrete.
I probably have 18" from the back of my boiler to the concrete wall. I wish I had more room to be honest. But based on my layout I couldn't really justify moving the boiler further outl. I'd say 18" is the bare minimum. Personally, if it's a combustible wall I wouldn't go closer than the recommended clearance due to insurance reasons.
when you say combustible wall do you mean exposed wood studs?
If so, just cover it with 5/8" fire rated sheetrock one layer will be fine two will be better.
That would not be a code approved way to reduce the clearances to combustibles.
I just went through this whole thing actually... Still working on it (Ill have pictures to show later!)
Two sheets of fire code sheet rock (on 2x8 studs) provides a 1 hour fire rating, but isnt necessarily a reduction in clearance to combustibles. It depends on your local code, but I followed this : http://publicecodes.citation.com/st/ny/st/b1100v10/st_ny_st_b1100v10_3_sec008_par005.htm Thats for NYS, so YMMV.
I used the sheetmetal held off of the two layers of sheetrock with fencepost insulators (Thanks for the idea Mr. Dudley!) and that technically cuts my clearances in half. If you are reducing vertical clearances, you can reduce it to 1/3rd.
All of this is subject to your local code guy and your insurance company, so please use the appropriate grains of salt!
