I cleaned the stove glass with.....
truck243
41
louisville ky
I've tried a few different ways of cleaning the stoves glass door, but I just used ammonia on a paper towel on a warm stove glass, and it worked like majic, almost no effort, I hate the smell of ammonia, but I finally found a use for it.
Ammonia on glass ok,ammonia on ceramic isn't good.Check your manual.Hope ya find it,hate to see you mess up your window. Windex has ammonia also.The stove ash works better than the wood stove glass cleaner i bought.
Take and spray alittle wood stove glass cleaner on the paper towel and then dip it in some ash and it really takes to the crud off of the ceramic.
Water and ash. Works great and it's free.
Mr. Clean Magic Eraser....best ceramic glass cleaner ever....just wet it, wring it out, rub off the crud, wipe dry with a paper towel......do it when the glass is cold, of course...
Water works just fine for me. You are just cleaning off a little ash anyways.
I just use a damp paper towel and just scrub a little harder on the darker stains. But as everyone here say's good dry wood and a hot fire does wonders to keep the glass clean. It took me a few seasons to fully understand the meaning of dry wood, and a moisture meter helps.
Brian
I just tried the water and ash + paper towel-it's true, works well!
I keep a small bottle that can MIST rather than spray and use full strength Simple Green. I love the stuff all around but this method applies only a mist that coats the glass and doesnt cause it to run down the glass. 15 seconds to do its stuff, and one select-a-size paper towel and its clean as it ever was.
I've had good results with Rutland glass cleaner. Doesn't take much, and no scrubbing needed.
I clean the window with my ash. LOL But I have a bottle of Rutland glass cleaner left over from the pellet stove days. It's a good product and does the job.
+1
Use it on the pellet stove also as it only runs on low so the glass gets dirty
Aaron
I had dirty glass my first year burning. Then I joined Hearth.com. I read the posts about ash & water. Then I read that if you burn hot and only dry wood there will be littlte to no need
to clean glass ever. It took me a while to get it but now its all good.
Here is another vote for damp rag, maybe some ash, maybe some elbow grease. I don't have to do it often, but the corners sometimes get smudged and I want to clearly see the whole fire including the corners.
+1 on this. Dry wood and hot fire = little to no problems.
i use a bit of soapy water. does a good job.
Water and ash work just fine. A few times a season I'll use Rutland conditioner which works great on any stubborn areas.
rutland glass cleaner. It seems less messy than stove ash but ive never tried the ash. The rutland cleaner doubles cleaning my range ceramic top, so i have it anyways.
When I picked up the Intrepid the glass was opaque. Couldn't even see through it. Dark creosote build up in several areas. Water, ash, and paper towel was still able to clean it up quickly.
I love the rutlands glass cleaner that was shown. Some people have said that ash used over time can put in small scratches, so I don't want to take any chances. The rutlands is inexpensive, less than $5 and they carry it at Lowes. One bottle lasts me all winter. It works better than anything else I've tried, vinegar, magic eraser, etc.
Damp rag and water . . . doesn't get much easier or cheaper than this . . . although it helps to also burn seasoned wood and burn at the proper temps.
