1 bag 18 hours on low setting does that sound right ? thermostat set at about 72 but it pretty much runs all the time to keep up i guess. This was over night so i really dont know how much it went on and off but im thinking it ran constantly
sounds ok, I put in a bag every day. I typically use around 4 ton per year, I usually start burning sometime in mid to late October and end in late April early May. i run it in auto mode set at 74, which keeps the house at 72 because when it reaches 2 degrees before the set temp on auto, it ramps down and keeps running, saving the ignitor.
That sounds about right. I average a bag a day in Jan to Feb depending on the temp outside. Some brands burn faster some burn slower. I burn on manual MH. We have a 2 story colonel, What work for me is get the down stairs hot (78-80) and let the heat rise to the second floor. Maintaining a higher temp does not seem to use a lot more pellets.
If you don't have the battery cable for the stove I would suggest getting it with a agm marinia battery. Ran all day yesterday on battery while I got the generator going. With 10 inch snow on the ground and no power it was great to have heat.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
