FPX Elite 44 vs RSF Opel 3
drider
3
Oregon
Hello all, I need some help in choosing a fireplace for my house that is going to be built this next summer. In my research Hearth.com kept coming up so I thought I would join and just ask. The house that we are planning on building is 2600sqft with 9 ft ceilings on the first floor. The fireplace will be on the first floor. Their are three bedrooms as well as a family room on the second floor. The first floor has a living room, kitchen, dining room, master and an office. The fireplace will be on an exterior wall and the face of the fireplace will be flush with the wall. What ever fireplace we choose needs to be EPA certified since we have a strict fire burning policy in the area. The fireplace also needs to be zero clearance because that's just what we want.
We have considered the Lennox Montecito Estate/BIS Tradition, Valcourt FP9, but the closest dealer that their website says is their dealer has never heard of them. Which brings us to the FPX and the RSF. If we did the RSF Opel 3 we would do a clean face kit and hook it into the Central Heating system. Also I would have to find someone to install it or do it myself since the nearest dealer is about an hour and a half away and is not very interested in doing the install.
So I guess my question is which fireplace will keep our house the warmest in the winter with the heat spread throughout the house as evenly as possible? We don't want it 90 degrees in the living room and 65 in one of the bedrooms. What can we expect for burn times for the FPX and the RSF considering that we don't have any real hardwood around here to burn? My wife likes the look of the FPX mostly because it is big, but she said that she would go with what ever would heat the house better. How well does the FPX posi pressure work compared to just hooking into the central heating ducts with the RSF?
From what I have read the FPX puts off a ton of heat we just want to make sure that heat moves throughout the house and whenever I see someone comment on the RSF they just say "it heats my 3000sqft house well". So which would be better for us?
Thanks
Fist off, welcom to hearth.com!
As for the fireplaces, I think they both have their advantages... Hopefully someone else here can help out more but here's a few basic things that I noted about them-
*the FPX has a larger firebox, which means you could go longer between reloads. The FPX also accepts a much longer log than the RSF
*the FPX puts out slightly less emmisions than the RSF
*the FPX would probably take up more room than the RSF
You should still be able to get good burn times off of softwood like pine & fir. I don't know about RSF, but I believe that Travis Industries (FPX's parent company) runs their tests with softwoods common to the NW (their factory is just one state away from you in Wa!)
I think either way you go, you'd be satisfied, as I've heard many a good thing about both FPX's & RSF's.
I do have to agree with you wife in prefering the looks of the FPX, though. ;)
Good luck!
I have an FPX44. Where this unit sits is a sunken 600 ft2 room with 25' vaulted ceiling. That unit will flat heat that room up in two hours from 68 to 75 in about 2 hrs from the time I light the wood - I'm able to use Oak. It's easy to build fires in the unit and control - but it does want to burn quickly for sure. Could be my 35' of chimney, dunno. Easy to get a fire going in it. The rest of the house gets rather comfy, too when I've had the chance to run it for the day for sure.
I can also tell you that for in my area, the mere thought of hooking up a fireplace to an HVAC unit freaked out the folks around here I talked to - so if you are banking on doing that with the Opel do your research and talk to folks before you buy. Hooking up to your HVAC, although doable, is something I'd consider very carefully before I did it myself. Several HVAC folks had horror stories to tell so they flat refused to even consider it. And you'll also need to be sure your air handler can deal with the increased temperature if the air if I recall correctly.
Obviously I liked the FPX as it has a real clean look and didn't have the vents and louvers of the other units, and I'm telling you - it'll put out the BTU's for sure. I also was able to hook mine up for outside air since I'm in a temperate zone.
I'd be less concerned with hooking up the FPX myself as the manual is pretty detailed. And don't kid yourself - whatever unit you get and whether it's hooked up to the HVAC or not, the room the unit is located will be warmer than the other rooms. I have a variable speed blower for one of my HVAC units so when I turn my fan on it's a low RPM setting that just moves air around. Really helps I believe.
Thank you for the info. We are currently leaning towards the fpx but are just worried that it won't get the heat to the entire house.
How well the heat moves in your house is more closely related to your floor plan and your ability to move the air, rather than the primary selection of fireplace. The FPX has the heat output. If you keep it running the posi pressure does a fairly good job of moving the air. It will be warmer in the room with the fireplace, anything you can do to distribute the warm air, the more uniform the temp will be. (ie ceiling fans, running blower or air circulate on your furnace, etc.)
Depending on your wood and the amount you load up, I usually get anywhere from 2-4 hours of primary real world high heat burn time. You can have hot coals easily 12-14 hours later. I have raked and restacked as much as 20 or more hrs later without the use of matches or paper. Disclaimer: My wood is very dry and may shorten the burn times.
I have no real knowledge or experience with the RSF - my impression from following the forum is it is a solid option.
I have the FPX 44. I find the POS system to work well distributing the heat. Given the layout you described I think it will work well for you. I use it to provide close to 100% (away times the oil may kick on, thermostat set low) of the heat for our house which is similar in size and layout to what you described.
If there is a "con" for the 44 I would say we go through a lot more wood than I hear from others running a wood stove. Not sure compared to other zero clearance units. I have heated for 3 winters here in New York and have consumed between 5-6 cords a year.
I'll attached a recent photo - we LOVE the look of it
Thanks for the information. My wife really likes the idea of the central heat option, but we will see. What are your guys thoughts on having cold exterior air circulate through the fireplace. I was talking with a family friend yesterday from my hometown who sells both the rsf and the fpx and he was a little worried about the cold air where I live for the fpx. He was talking to me more as a friend since it would be a 4 hour drive one way for him to sell me a fireplace. We get down to single digits at night and sometimes below zero in the winter. He was telling me though that either way they both should heat the house well.
We get plenty of cold weather here... heck we had over a foot of snow Saturday (highly unusual)! I have read about the concern of bringing in cold air but have not experienced any problems. The bigger concern was when the fireplace is not in use and creating a cold draft... I think Travis fixed this as I have not had any issues but to be fair, when its cold I'm running the 44.
We get the single digits too and a couple days a year it goes below zero. One of the main reasons I purchased the FPX is the external blower. I like the idea of bringing in fresh air all winter. When I first installed the unit, on the coldest nights the blower would kick out, especially if you turned it up high. This related to the blower sensor getting too cold. I took it out, added insulation behind and have not had a problem since.
If you are really concerned.... and you have a basement you could intall the blower to pull air from there instead.
I am not a 24/7 burner and I can tell you I have zero cold air intrusion when the unit is off. I did locate the blower and the cooling duct intakes below the unit just as an added measure. My thinking....as cold air does not rise.
Wood consumption is high compared to some of the freestanding stoves, but acceptable to me as we really wanted the fireplace look.
Not sure on the RSF but the FPX burns very clean. Once you got the fire going and CAT burning there is zero smoke. Another bonus if you have neighbors close.
My only con so far: does not produce much heat in a power outage without the blower running. Solution = generator.
